Account management
This article is a stub.
Template:Old style Template:Learned
User Account management
- User management is the process that focuses on the administration of users of IT and information systems. This process manages the registration of users and the authorisation of their roles within a system. Authorised access is secured with a user specific login name and password.
- User Management can control, for example:
- The projects a user can access
- Whether access to that project is read-only
- If a user can update his credentials (login, password)
- If a user can update relevant project data
- If a user can host or join a session with other users
Different account types in the Tygron Web Application
- The Tygron Web Application uses account management to enable user access to their proper projects, and with the required rights to perform the actions desired. To ensure that users have access to their assigned projects, and their assigned projects only, users are grouped in so called user domain groups (="domain"). Within a domain, users can have different roles, or account types, assigned. These types or roles determine the actions a user can perform within his domain. These different account types are described below:
Invite Only
- The Invite Only account type is the account type with the lowest access level. When using this type, the user can only be invited to a session. Within the domain at least one Multiplayer account type must be available, to be able to host sessions where Invite Only accounts can be joined to. The user can only perform a minimum of actions, such as:
- Run the hardware benchmark test
- Call up online support resources, such as the Wiki and Forum
- Read the Legal Notices
- Log out of the Tygron Web Application
Single Player
- With this account type it is allowed to start available games in Single Player or Demo mode besides the options available for the Join Only account type. Thois account is used when there are both single player and multiplayer games available in the domain, however, it is desired to restrict access to only the single player project(s) for one or more users within the domain.
- With this account type users can:
- Change user account details (name, family name & password)
- Start a game session in Single Player or Demo mode
Multiplayer
- The Multiplayer account is used for hosting and joining game sessions for multiple users. With this account type a user can select, besides the same options as the Single Player account, to host a new or previously saved multiplayer game session, or to join an already active multiplayer game session. This is the most common account for the general purpose of participating in multiplayer sessions.
- Host a new or already saved multiplayer game session
- Join an already active multiplayer game session (hosted by someone else)
Editor
- This account type has the same options available as the Multiplayer account type. This account type can also create new games, edit existing games, or join others within the same domain, in an editing session.
- Create a new or edit an already saved game project
- Join an already active editor session with another user within the same domain
Domain Admin
- The Domain Admin account has the highest access level available to end users of the Tygron Engine. This account has all the perks of the Multiplayer account plus the options to manage all the users in the domain, manage the available projects within the domain, manage the active sessions within the domain and the license for the domain. If no domain admin account is available within a domain, this role is being taken care of by Tygron Customer Support.
- Create or change users within the domain
- Manage the projects within a domain
- Manage active sessions within a domain
- Change the license of the domain
Account Type | Description | Available options in main menu |
INVITE_ONLY | This account can only be invited to a multiplayer session | Invite only |
SINGLEPLAYER | This account can only access Demo and Single Player sessions | |
MULTIPLAYER | This account can start and join multiplayer sessions, including the inviting of other users | |
EDITOR | This account type can, besides hosting and participating in multiplayer sessions, create and edit its own projects | |
DOMAIN_ADMIN | This account is the highest access level available. With this account you can also manage other accounts from your user domain. |
Domain
- User accounts are grouped under a "domain" (=user group). This is a convenient manner to ensure that users from a certain group can only access the games assigned to their domain. This to avoid competitors to be able to sea each others games for example, or to avoid caustic behaviour such as editing or deleting games from other user domains. Using Permissions you can decide which user is allowed to edit a project or host a session of it.
- Please note that the licensing is also linked to the domain; a domain receives a license, not the users individually!
Domain license types
- A domain is licensed for using the Tygron Engine. This means that there is a limit on projects per domain, not a limit on the amount of users or projects per user. Licenses divided over different classes and types of licensing. A domain receives, for starters, an Educational or Non-Educational class license. The Educational class is dedicated to educational users, such as educational institutions and students. Within this licensing group also a free trial license can be requested. Non-Educational class licenses are for commercial parties, without educational purposes.
- For both classes different types of licenses are available:
Use only, no editing
- This license is commonly used for facilitating sessions of already existing projects, such as the Climategame or the Krimpgame. The user has only access to the already available projects in their domain, which are usually created in another domain and then shared with this "Use Only" domain. No new games can be created or edited, so there is no use for an editor account with this license.
1 Project
- With this license only one project can be created and edited on the Tygron Server. Support is also only available for this project.
5 Projects
- With this license five projects can be created and edited on the Tygron Server. Support is available for all five projects.
10 Projects
- With this license ten projects can be created and edited on the Tygron Server. Support is available for all ten projects.
Unlimited
- With this license an unlimited amount of projects can be created and edited on the Tygron Server. Support is available for all projects.
Changing user account and user domain details
User details can be changed in the "users" menu. You can find this menu by selecting "Options" from the main menu.
