TQL
TQL
The Tygron Query Language is a special-purpose programming language designed for obtaining spatial area information during a specific project session in the Tygron Engine. The primary reason for its introduction was to bridge the gap between the Tygron Engine and the implementation of Microsoft Excel spreadsheets.
Queries
The main operation used in TQL is the query, which is performed with the declarative SELECT statement or UPDATE statement. A declarative statement tells the system which data is specifically required, after which the system will retrieve the data on it's 'own'. This is contrary to an imperative statement, where the system is told 'how' to obtain said data. A SELECT statement retrieves data from a running Tygron project session. An UPDATE statement changes data of a running Tygron project session. Queries using SELECT statements have no persistent effect on the project session itself.
Queries in TQL using the SELECT statement allow the user to describe the desired data, leaving the Tygron Engine responsible for planning, optimizing, and performing the physical operations necessary to produce the desired result as output.
Queries using the UPDATE statement are used for calculations in Excel. The outcome of the calculations are used to change the data of the project in the Tygron Engine.
When starting a query with the SELECT statement, a result parameter must follow after the SELECT keyword. Currently, one of the following result parameters can be selected:
| Result Parameter | Description | Example |
FLOORSIZE
Floor size of buildings. | SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES
LOTSIZE
Lot size of buildings. | SELECT_LOTSIZE_WHERE_CATEGORY_IS_OFFICES
UNITS
Amount of housing units. | SELECT_UNITS_WHERE_CATEGORY_IS_SOCIAL
LANDSIZE
Amount of surface area. | SELECT_LANDSIZE_WHERE_BEHAVIOR_IS_GRASSLAND
DIKES
Surface space of constructed dikes or levees. | SELECT_DIKES_WHERE_ZONE_IS_1
ACTIVE
whether something is relevant in the project. | SELECT_ACTIVE_WHERE_ZONE_IS_1
NAME*
Name of selection as query result | SELECT_NAME_WHERE_CATEGORYMULT_IS_SELL_PRICE_M2
COLOR*
Color of selection as query result | SELECT_COLOR_WHERE_FUNCTION_IS_816
GRID_AVG
Average grid value per grid point | SELECT_GRIDAVG_WHERE_GRIDTYPE_IS_TRAFFIC_NOISE
* can be followed by one clause maximum
When starting a query with the UPDATE statement, the result parameter is predefined in the statement. One of the following result parameters can be selected:
UPDATE_AREA
Update the area attribute. | UPDATE_AREA_COLOR_WHERE_AREA_IS_0
UPDATE_BUILDING
Update the building attribute. | UPDATE_BUILDING_TRAFFIC_FLOW_WHERE_BUILDING_IS_64
UPDATE_GLOBAL
Update the value of the global. | UPDATE_GLOBAL_VALUE_WHERE_NAME_IS_COSTS_WATER_SYSTEM
UPDATE_NEIGHBORHOOD
Update the neighborhood attribute. | UPDATE_NEIGHBORHOOD_COLOR_WHERE_NEIGHBORHOOD_IS_3
UPDATE_PANEL
Update properties of the panel. | UPDATE_PANEL_VISIBLE_WHERE_PANEL_IS_1
UPDATE_ZONE
Update the zone attribute. | UPDATE_ZONE_AMOUNT_FLOORS_WHERE_ZONE_IS_589
Comparison Predicate
The SELECT and result parameter are followed by a WHERE statement. The WHERE statements contains a comparison predicate, which are logical propositions that restrict the information retrieved by the query. In other words, the WHERE clause eliminates all information from the result set where the comparison predicate does not evaluate as being valid (Boolean = True).
Take for instance the following statement as example of a logical proposition:
- The Student is a Senior.
This statement excludes all students that are Junior, Sophomore or Freshman, as the outcome of the logical proposition would be 'False' in these cases.
The comparison predicate consists of 0 or more clauses, which consist of three parts;
- Clause Type
- Operator
- Value
Clauses
Some clauses are particular for constructions, others are applied to surface areas of constructions or dikes. The clause types and expected values currently supported are:
| Clause Type | Description | Value Type | Example |
CATEGORY
A construction belongs to the specific Function category | Function category | CATEGORY_IS_INDUSTRY
CATEGORYMULT
A category multiplier, a fixed value for a given Function category | Function value | CATEGORYMULT_IS_BUYOUT_COST_M2
BEHAVIOR
A specific type (= behavior) of land or open water | Land | BEHAVIOR_IS_GRASSLAND
BEHAVIORMULT
A category multiplier, a fixed behavior value for a given Function | Function value | BEHAVIORMULT_IS_GREEN_FACTOR
FUNCTION
A construction belongs to a specific Function | Function ID | FUNCTION_IS_621
FUNCTIONMULT
A function multiplier, a fixed function value for a given Function | Function value | FUNCTIONMULT_IS_WATER_STORAGE_M2
DIKE
Surface area lies (partly) within a particular type of Dike (or Levee) | Dike ID | DIKE_IS_0
MAP
A construction or dike is present in the specified map or view. Also see Simulation Type | CURRENT or MAQUETTE | MAP_IS_MAQUETTE
STAKEHOLDER
A construction or surface area is owned by a specific Stakeholder | Stakeholder ID | STAKEHOLDER_IS_7
STAKEHOLDERTYPE
A construction or surface area is owned by stakeholders of a specific Stakeholder Type | Stakeholder Type | STAKEHOLDERTYPE_IS_COMPANY
STATE
A construction is in specifide State | State Type | STATE_IS_PENDING_CONSTRUCTION
TERRAIN
Surface area lies (partly) within a specific Terrain | Terrain ID | TERRAIN_IS_1
TERRAINTYPE
Surface area lies (partly) within terrains with a specific Type of Terrain | Terrain Type | TERRAINTYPE_IS_SAFE_ZONE
ZONE
Pertaining to an zone, or which lies within a Zone | Zone ID | ZONE_IS_25
GRIDTYPE
Type of grid used for a Grid Indicator | Grid Type | GRIDTYPE_IS_LIVABILITY
MINGRIDVALUE
Minimum treshold value for a Grid Indicator | Minimum grid value | MINGRIDVALUE_IS_50.0
MAXGRIDVALUE
Maximum treshold value for a Grid Indicator | Maximum grid value | MAXGRIDVALUE_IS_50.0
AREA
Pertaining to an area, or which lies within an Area | Area ID | WHERE_AREA_IS_0
AREA_WITH_ATTRIBUTES
Which lies within an area that can be assigned with a specific Attributes | An aera attribute | AREA_WITH_ATTRIBUTE_IS_COLOR
NEIGHBORHOOD
Pertaining to a neighborhood | Neighborhood ID | NEIGHBORHOOD_IS_3
NEIGHBORHOOD_WITH_ATTRIBUTE
Which lies within a neighborhood that can be assigned with a specific Attributes | Area Attribute | NEIGHBORHOOD_WITH_ATTRIBUTE_IS_URBANIZATION
ZONE_WITH_ATTRIBUTE
A specific part of a zone, or which lies within a zone that can be assigned with Attributes | Zone Attribute | ZONE_WITH_ATTRIBUTE_IS_MAX_BUILDING_HEIGHT
BUILDING
A specific Construction | Adress | BUILDING_IS_64
NAME
Name of the attribute or global | Attribute name | NAME_IS_TRAFFIC_LANES
PANEL
A specific Panel | Panel ID | PANEL_IS_1
LAYERTYPE
The selection of the constructions on the surface or in the underground | SURFACE or UNDERGROUND | LAYERTYPE_IS_SURFACE
Operators
TQL clauses currently support one Operator:
| Operator | Description | Example |
IS
Equal to | CATEGORY_IS_OFFICES
Simulation Type
Depending on the Simulation Type, the map parameter is named as follows in the Query Tool:
MAQUETTE
| Planning | ORIGINAL
PLANNED
| Timeline | TODAY
MODEL
State
During a project session in the Tygron Engine, construction states transform from one phase into another. For example; from being planned, to being permitted, to being constructed, to being ready.
The currently available states are:
| State | Explanation |
CONSTRUCTING
Construction is being constructed. |
CONSTRUCTION_APPROVED
Construction is approved. |
CONSTRUCTION_DENIED
Construction is denied. |
DEMOLISH_APPROVED
Demolition is approved. |
DEMOLISH_DENIED
Demolition is denied. |
DEMOLITION_FINISHED
Demolition is finished. |
DEMOLISHING
Construction is being demolished. |
NOTHING
Construction does not exist. |
Construction is waiting for the date to be constructed. |
PENDING_DEMOLISHING
Construction is waiting for the date to be demolished. |
PENDING_UPGRADE
Construction is waiting for the date to be upgraded. |
READY
Construction is done constructing. |
REQUEST_CONSTRUCTION_APPROVAL
Request is send to ask construction approval. |
REQUEST_DEMOLISH_APPROVAL
Request is send to ask demolition approval. |
REQUEST_ZONING_APPROVAL
Request is send to ask zoning approval. |
WAITING_FOR_DATE
Waiting to receive a date on which to start construction. |
WAITING_FOR_DEMOLISH_DATE
Waiting to receive a date on which to start demolition. |
Query Tool
In order to make it easier to construct queries, a tool has been developed to create queries in the editor, which can then be copied and used elsewhere. This tool is known as the Query Tool and more information can be found on its own page.
TQL Uses
TQL is currently used for communication between a (custom) Microsoft Excel spreadsheet and the Tygron Engine.
