Geo Data
What is GEO Data
How does GEO Data relate to the Tygron Engine?
What GEO Data sources are used?
The Tygron Engine uses automatically connected Geo Data sources for The Netherlands to generate the 3D World. When the selection is made on the map in the wizard the 3D World is built up based on the available GEO Data in the connected data sources. For all the different environmental elements the data base with the most complete and relevant Geo data is connected. All together this forms the 3D World. For this proces the principle applies: If you miss something in your 3D World it is not available in the data base otherwise it would be present in the 3D World. To complete the Geo data you can either update the information in the data base, or you enter additional Geo data manually. More infomation about how you can enter the data manually is also explaind in the topics Overlays and GeoJSON.
Add pic of loading.
Name | File Type | Source | Description |
BGT | GML-File | PDOK | Information about street objects, roads, parks, trees, water surface, etc. |
BAG | OGC-service | PDOK | Information about building contours, building type definitions, construction year, etc. |
Aerial View | ESRI service | ESRI / CycloMedia | For basic texture of landscape, color of the roofs. |
DEM | ESRI service | ESRI | Digital Elevation Model: the terrain height (excluding buildings). |
AHN2 / 3 | ESRI service | ESRI | For service area including building height. Determination of roof types, building sections and elevations. |
Neighborhoods | OGC service | PDOK / CBS | For determination of communities and neighborhood information. |
Zoning | GML service | Ruimtelijke Plannen | Information about i.a. authorized dimensions and -functions of buildings. Also additional feature attributes such as Monumental status. |
Top10NL | OGC service | Tygron / PDOK | Backup for BGT, among others locations of ocean surface, highways, railways. |
NWB | OGC service | PDOK | Names of roads and ID information for INWEVA. |
INWEVA | Excel | Rijkswaterstaat | Information on all major roads in The Netherlands including the intensity of the road sections. |
BRP | OGC service | PDOK | Information on what kind of crop fields (corn, potatoes, etc). |
Cadastral map | OGC service | PDOK | Information about land ownership. |
CycloMedia | CycloMedia | CycloMedia | Information about locations of windows, floors, wall color of buildings. |
Risk map | GML service | Risicokaart.nl | Information on hazardous- and / or nuisance buildings, for exapmle LPG station. Also additional information on vulnerable buildings like hotels, pension, etc. |
Natura 2000 | OGC service | PDOK | Information about nature. |
Build in possibility to add additional GEO Data from the Tygron Engine | |||
PDOK maps | OGC service | PDOK | Ability to add PDOK of additional cards if desired. |
ArcGIS Online maps | ESRI service | ESRI | Ability to add ArcGIS Online additional cards if desired. |
When to use GEO Data?
When a project is created outside of The Netherlands only ESRI data is connected and will load automatically. Beside water and elovation of land, this does not contain any information about constructions and/or environmental characteristics.
