Version 2018.0.0
Revision as of 10:43, 2 November 2017 by Maxim@tygron.com (talk | contribs)
Version 2018.0.0 is to be released on preview.tygron.com on Friday November 3th 2017
From November 3rd the complete release note overview will be present here.
Geo
  • New Geo Data Wizard
  • Wider support for different Online Geo sources. For example GML3 with old GML2 tags are now supported.
  • Improved filtering options to select specific features and assign them to specific stakeholders, functions, etc.
  • Generalized, all Geo Import now follows the same flow/wizard.
  • All objects now keep a Source reference, that can be used to check where the data came from later.
  • Source Overlay that shows the different sources used in the project.
  • Data from all EPSG Projections can now be imported.
  • Option to select a different EPSG Projection for exports.
  • Better "out-of-the-wizard" support for Satellite images and Height data outside The Netherlands.
Overlays
  • Updates to Rainfall configuration Wizard. For example feedback on invalid data in weirs, pumps, etc.
  • New Subsidence configuration Wizard.
  • Both Rain and Subsidence are connected to the Geo Data Wizard.
  • Avg Overlay can now also only calculate averages for single cells. Useful for showing rasterization of data used in other overlays.
  • Avg Overlay can now also show values from a specific layer (e.g. buildings or areas)
GUI
  • Improved Navigation Panel that makes it easier to switch between 2D Overview and 3D details.
  • Improved the address Search bar in the Navigation panel.
  • Zoom Navigation can now also be done by double clicking in the map. Or just use space bar for faster switching.
  • Smaller overlay legend panel so it does not take up to much space.
  • Option to align custom (excel) panels to other parts of the screen.
  • Download bar when starting the application now correctly updates from 0%->100%.
  • Error in TQL/Excel calculation are now displayed more prominent, so you cannot miss them anymore.
Other
  • Integration with the new FreshDesk Support Portal.
  • New underlying infrastructure of the Engine reduces the amount of connection lost messages.
  • Improved water visualization that reduces artifacts around banks/shores.
