Version 2018.0.0
Version 2018.0.0 was released on engine.tygron.com on Friday January 26 2018
Geo
- New Geo Data Wizard
- Wider support for different online Geo Data sources. For example WFS and CSW. Also GML3 with old GML2 tags are now supported.
- Improved filtering options to select specific features and assign them to specific stakeholders, functions, etc.
- Generalized, all Geo data import now follows the same flow/wizard.
- All objects now keep a source reference, that can be used to keep track of data changes/sources.
- The Source Overlay that shows the different sources used in the project.
- Geo data in different Coordinate Reference Systems are now supported in the Engine.
- Option to select a specific Coordinate Reference System for exporting data.
- Better "out-of-the-wizard" support for Satellite images and Height data outside of The Netherlands.
- Also an option to import an elevation model.
Overlays
- Updates to Rainfall configuration Wizard. For example feedback on invalid data in weirs, pumps, etc.
- New Subsidence configuration Wizard.
- Both Rain and Subsidence are connected to the Geo Data Wizard.
- Avg Overlay can now also only calculate averages for single cells. Useful for showing rasterization of data used in other overlays.
- Avg Overlay can now also show values from a specific layer (e.g. buildings or areas)
GUI
- Improved Navigation Panel that makes it easier to switch between 2D Overview and 3D details.
- Improved the address Search bar in the Navigation panel.
- Zooming in can now also be done by double clicking in the map. Or just use space bar for faster switching.
- Smaller overlay legend panel so it does not take up too much space.
- Option to move a custom (excel) panel to another part of the screen.
- Download bar when starting the application now correctly updates from 0%->100%.
- Errors in TQL/Excel calculations are now displayed more prominent, so you cannot miss them anymore.
Other
- Integration with the new FreshDesk Support Portal.
- New underlying infrastructure of the Engine reduces the amount of connection lost messages.
- Improved water visualization that reduces artifacts around banks/shores.
- Easier to reset tokens for Web Clients.
- Sessions marked as keep-alive will automatically be restarted after the server was down for maintenance.
- TQL now has and new option DISTANCE, that can be used to get the distance between e.g. a Building and a Neighborhood.
- You can now create a Global value directly from an TQL Query. This allows you to instantly see changing TQL Query values in the Global Values panel.
