Version 2018.0.0
Version 2018.0.0 is to be released on preview.tygron.com on Friday November 3th 2017
From November 3rd the complete release note overview will be present here.
Geo
- New Geo Data Wizard
- Wider support for different Online Geo sources. For example GML3 with old GML2 tags are now supported.
- Improved filtering options to select specific features and assign them to specific stakeholders, functions, etc.
- Generalized, all Geo Import now follows the same flow/wizard.
- All objects now keep a Source reference, that can be used to check where the data came from later.
- Source Overlay that shows the different sources used in the project.
- Data from all EPSG Projections can now be imported.
- Option to select a different EPSG Projection for exports.
- Better "out-of-the-wizard" support for Satellite images and Height data outside The Netherlands.
- Option to also import "Measure Buildings" with Geo Data.
Overlays
- Updates to Rainfall configuration Wizard. For example feedback on invalid data in weirs, pumps, etc.
- New Subsidence configuration Wizard.
- Both Rain and Subsidence are connected to the Geo Data Wizard.
- Avg Overlay can now also only calculate averages for single cells. Useful for showing rasterization of data used in other overlays.
- Avg Overlay can now also show values from a specific layer (e.g. buildings or areas)
GUI
- Improved Navigation Panel that makes it easier to switch between 2D Overview and 3D details.
- Improved the address Search bar in the Navigation panel.
- Zoom Navigation can now also be done by double clicking in the map. Or just use space bar for faster switching.
- Smaller overlay legend panel so it does not take up to much space.
- Option to align custom (excel) panels to other parts of the screen.
- Download bar when starting the application now correctly updates from 0%->100%.
- Error in TQL/Excel calculation are now displayed more prominent, so you cannot miss them anymore.
Other
- Integration with the new FreshDesk Support Portal.
- New underlying infrastructure of the Engine reduces the amount of connection lost messages.
- Improved water visualization that reduces artifacts around banks/shores.
- Easier to reset tokens for Web Clients.
- Sessions marked as keep-alive will automatically be restarted after the server was down for maintenance.
