Panel
This article is a stub.
Panels
Panels, in a software context, are windows, dialogs or similar generic interface elements which are presented to a user. They can be small prompts or dialogs which facilitate an inquiry or message towards a user. They can also be larger, more complex interface components with multiple texts and/or elements on them.
Panels in the Tygron Engine?
Release Notes Panel from Editor
In a project, panels are a term specifically used for a user-defined interface element, which can be created and configured in the editor. They are purposefully left generic and abstract. The contents are entirely left open for a project- or template-specific implementation. Panels can be placed in the 3D world, where they are represented by a popup which can be clicked to open the panel. They can also be opened via a client event, or left entirely unavailable.
Most panels render a html content. This means they can display text without additional formatting, but can also be styled using html, css, and javascript. This has the added benefit that those panels can also be opened in a web browser, or included in the rendering of a web interface.
Panel types
There are 5 types of panels available in the Tygron Engine.
Panel type Description Functioning
Text panel The contents of the panel are defined directly as text. The text is interpreted as html content and directly displayed as content of the panel. If it's html-formatted content, it will be displayed in that styled manner.
Web panel The contents of the panel are defined by a url. The web page at that url is used as content for the panel. When attempting to open the panel in a web browser, the web page will be accessed directly (i.e. not via the Tygron Engine).
Global panel One or more globals are linked to this panel, allowing an end-user to edit the values of those globals during a session. The panel has a predefined structure in the session interface, and a fixed location. For each linked global, an input field with that global's value is displayed. The value can be changed and submitted by an end-user in the session. This will change the value of the global to the entered value. This panel does not have an html representation, and cannot be opened in the web browser or be made part of the web interface.
Excel panel The contents of the panel are defined by an excel file. Each time data in the project or session is updated, the excel file is recalculated. The results are interpreted as (html-formatted) text, and displayed as such. Effectively, this panel is similar to a text panel, but rather than a static definition for the text contents, the definition is dynamically generated via the excel.
Template excel panel This is not a panel by itself, but forms a definition by which panels can be generated automatically. The "instances" of these panels behave as regular panels. Based on how the template panel is defined, a number of "instances" of the panel will be generated. Configurations such as the size, model, and attributes of the panel are carried over directly. The panel name, the assigned stakeholder, and certain queries in the excel are modified based on what the template panel is applied on.
Properties of panels
Panels have a number of properties which can be configured in the editor. They also allow for the definitions of arbitrary attributes.
Name
When a panel is opened, the name of the panel is displayed at the top, so the end-user knows what the panel is about.
Sizing
The size of the panel can be adjusted, so that it fits the content properly without cutting it off or leaving a large amount of empty space. It's also possible to set where in the interface the panel should appear.
Availability
When the panel is placed in the 3D world, it can be set to be visible or invisible. If it is visible, it can also be set to draw attention or not. They can also be configured so that a panel is only accessible by one specific stakeholder, rather than all stakeholders.
Visualization
When the panel is placed in the 3D world, the popup representing it, and which can be clicked to open, is a green tick mark by default. This icon can be changed to a different symbol, as offered by the editor. The selected symbol has both a 3D representation, and a 2D representation for higher zoom levels, and for the web interface.
Overlay
A panel, by itself, may not provide all the information you wish to show. It's possible it's related to geographical information, visualized in an overlay. A panel can be related to an overlay, such that when the panel is opened the related overlay is opened as well.
Content
The core functionality of the panels is the content. Depending on the type of panel, the type of content differs. However, if a panel has no content, the panel generally has no purpose.
Panels can have any number of arbitrary attributes, which allow for additional data to be attached to them in an accessible and alterable manner. Some attribute names are reserved and have a special function.
ATTENTION: Whether the panel is drawing attention. This is an attribute representation of the attention property. Changing this attribute causes the panel to draw attention or not.
COLOR: The color of the 2D icon of the panel's popup. This can be used to differentiate popups from one another. An additional effect of different colors is that when you zoom out to the 2D view, icons of different colors are not combined.
POPUP_TYPE: The model of the panel's popup. Changing this attribute changes the icon of this popup.
SCALE: The size of the 2D icons of the panel's popup in the 3D world. Note that the size is only updated when the visibility of the panel is updated. Either because it is (re)placed in the world, or the visibility is toggled.
VISIBLE: Whether the panel is visible. This is an attribute representation of the visibility property. Changing this attribute causes the panel to become visible or invisible.
Answers
A panel can be given "Answers". These are buttons that are added to a panel, which allow an end-user to close it by selecting a specific response or option. These answers can be further enriched by adding events to them. When the user views the panel, and they select an answer with one or more events attached to it, the events are fired and changes can be effected in the session.
Use-cases for panels
Information
The most obvious use for panels is to provide information to the end-user. By making a panel accessible, any text or images displayed on it provide a source of (static) content in the session. Especially text panels and web panels are used primarily for this purpose, but especially excel panels can provide information, even dynamically, about the current state of things in the session.
Interaction
Panels can offer options to interact with the session as well. Either answers can be added to a panel, or the html content can define buttons which send instructions to the project via the API. With some work, it's possible to define complex interactions with the 3D world via panels. Text, web, and excel panels can all be used with answers. Text and excel panels can most easily be used to add html buttons and input elements as well.
Calculation model
By not placing the panel anywhere in the world, and not making the panel otherwise accessible by the end-users, it is possible to add a calculation model to a project without "unintended" side effects. For example, if a project requires a dynamic traffic model, an excel panel can be added to the project, with an excel sheet with the appropriate calculations and queries. It would use SELECT queries to retrieve information from the project, use some calculation to determine the appropriate amount of traffic in the various locations in the 3D world, and then use UPDATE statements change the traffic intensities in the 3D world. By placing this calculation model in an unreachable panel, no stakeholder will see any trace of this calculation model, other than the changing traffic intensities.
Web interface
Main article: Web interface
In the web interface functionality, it is possible to enrich the web interface with your own html, css, and javascript, to provide the functionality you want to the end-users experience. Panels provide the primary means of adding your own information and programming.
Adding and editing single panels
Adding/removing panels
Template:Editor ribbon
The left panel for panels in the editor.
How to add a single panel:
  1. Select the desired panel type at the bottom of the left panel.
  2. Select "Add Panel".
How to remove a single panel:
  1. Select the "Single Panels" category in the left panel.
  2. Select the specific panel you wish to remove.
  3. Select "Remove".
Configuring panels
Template:Editor ribbon When you select a single panel, the right panel will be filled with the information pertaining to the panel. A number of properties can be configured.
The right panel for panels in the editor.
Name
The field for the "name".
The name of the panel. You can change this by altering the text in the "Name" field.
Panel Layout
The fields for the location.
The location of the panel, in pixels of distance from the bottom-left corner of the screen. "-1" places the panel in the default location. You can change this by changing the value in the first input field for the horizontal location, and the second input field for the vertical location.
Panel Width & Height
The fields for the size.
The size of the panel, in pixels. The size set is the outer edge of the panel, there is some distance between the outer edge and the edge of the content placed in the panel. You can change the size by changind the value in the first input field for the width, and the second input field for the height.
Visible
The checkbox for visibility.
Whether the panel's popup should be visible in the 3D world. If the panel has a location in the 3D world, and the panel is visible, a popup is present in the 3D world, clickable by the end-user. If the panel has no location in the 3D world, or is not set to be visible, the panel's popup is not visible in the 3D world.
Request Attention
The checkbox for attention.
Whether the panel's popup should draw attention in the 3D world. If the panel has a location in the 3D world, and the panel is visible, and the panel draws attention, an arrow will appear for the end-user indicating where the panel is.
Assign to Specific Stakeholder
The checkbox and dropdown for the panel's stakeholder.
Whether the panel is only available to one stakeholder, or to all. If the checkbox is unchecked, the panel is available to all stakeholders. If checked, only the stakeholder indicated in the dropdown can see or access the panel. Other stakeholders will not be able to see the panel in the 3D world. If another stakeholder attempts to open the panel, for example via the web interface, they will get an error message that they are not allowed to access the panel.
Model
The model to use for in-map visualization.
The model used for the panel's popup. The model consists of both a 3D model for most zoom levels, and a 2D icon for the higher zoom levels and the web interface. Change the selection in the dropdown to change the used model and icon.
Overlay
The overlay to activate when the panel is opened.
When the panel is opened, this overlay should be activated to provide (additional) geographical information to the end-user. If set to "NONE", no overlay is used. Change the selection in the dropdown to change the used overlay.
Point in 3D World
The options to assign the panel to a geographical location.
A panel can be given a location in the 3D world. To do so, select "Set Point", and use the brush to select a position. To remove it from the 3D world, select "Remove Point".
Open Panel
The button to open the panel in the session interface.
To open the panel for testing purposes, you can select "Open Panel" to open the panel in the session interface. You can also open the panel in the web browser by selecting "Open in Web Browser".
Content
Depending on the exact type of panel, different elements may exist to configure the contents for the panel.
Text
The text content input field.
Enter a text in the "Panel Text" field, and that text will be set as the content of the panel. If the content is html-formatted, the content of the panel will be formatted accordingly.
Web
The URL input field.
Enter a url in the "Web link" field, and the indicated web page will be opened as content of the panel.
Globals
The globals selection list.
Select the globals which should be accessible via the panel, and those globals will be added to the panel.
Excel
The excel selection option.
Select the excel which should calculate the content for this panel.
Adding and editing template panels
Adding/removing template panels
How to add a template panel:
  1. Select the "TEMPLATE_EXCEL_PANEL" type at the bottom of the left panel.
How to remove an instance of a template panel:
  1. Select the "Template Panels" category in the left panel.
  2. Select the template panel from which the instance was generated.
  3. Select the specific panel you wish to remove.
  4. Select "Remove".
How to remove a template panel and all derived instances:
  1. Select the "Template Panels" category in the left panel. Select the template panel you wish to remove.
  2. Select "Remove".
Configuring and instantiating template panels
Template:Editor ribbon When you select a template panel, the right panel will be filled with the information pertaining to the template panel. A number of properties can be configured. Most properties are the same as for single panels. The important differences are listed here.
The right panel for template panels in the editor.
Name for template panel
The name of the panel. The name of an instance of a panel is composed of the name of the template panel, and the name of the item the template is applied on.
Stakeholder for template panel
The additional fields for the "stakeholder".
The stakeholder who has access to this panel. Rather than set a specific stakeholder, you can specify the type of relation the stakeholder should have with the item in question. For example, the "Use Owner" checkbox indicates that whoever owns an item at the time that the template panel is applied, is set to be the stakeholder with access to the panel.
The "Relational Filter" will make instances of panels appear only if the configured stakeholder has the indicated relation with the item the template panel is applied on. For example, if the filter is set to "Net Owner", and a stakeholder is set for the panel, there will only be instances of this template panel generated for those items of which the stakeholder is the net owner.
Template
The options for applying the template panel.
"Apply Template on" indicates what kind of item the template should be applied to. "With Attribute" allows a filtering on what items to apply the template panel to. If set, it will only be the items of the specified kind, with this specified attribute set to a non-zero value, for which panels will be created.
Not viewable
Note that there are no options to directly test what this panel will look like. This is because the template panel is merely a definition of how the actual instances should be structured, but which by itself is not an actual instance.
Applying
The "Apply Template" button will cause the actual instances of the panels to appear.
When the template panel is configured correctly, it can be used to create the actual panel instances which appear in the project. Select "Apply Template" to create the panel instances. You will be prompted with a message indicating how many panels will be created, which you can verify before creating the panel instances.
Editing panel instances
After applying a template panel, so that one or more panel instances are created based on the template panel, it is possible to edit them as though they were single panels. However, this practice is discouraged, because it is a common possibility that after applying the template, the template should be tweaked slightly to improve it and the instanced panels derived from it. After re-applying the template, any alterations made to specific instances of the panels are lost, as the instances are created anew. Instead, it is recommended to tag the items the panels are applied on using attributes, and including in the template panel itself some logic to handle the situations where that attribute is or isn't present.
Adding and editing answers
Adding/removing answers
  1. Select the panel you wish to add an answer to in the left panel.
  2. Select "Add Answer".
How to remove an answer from a panel:
  1. Select the answer you wish to remove.
  2. Select "Remove".
Configuring answers
When you select an answer, the right panel will be filled with information pertaining to the answer. A few properties can be configured.
The right panel for answers of panels in the editor.
Name for answer
The name of the answer. The name is displayed to the end-user when the panels is opened, and is the text of the answer the end-user may choose. The name can be changed by changing the value in the name field.
Events
The events fired when the answer is selected".
The events fired when this answer is selected. The events are decided into server events and client events. Server events will also trigger changes in the state of the session. Client events will only affect the visualization of the end-user who selected the answer.
