Water Overlay
What are the Water Overlays
When creating a new project in the new project wizard, take into account the Advanced options. In this menu for example the AHN3 dataset can be selected, which, if available for your project area provides the most recent heightdata available as Open Data. Also, the IMWA dataset is already checked, this means that if available in your project area, Water Level areas and/or Culverts are already imported.
Configuration Wizard
Step 1
Step 2
In the second step the elements of the water system can be imported. In some sub-steps the there are four options: to do nothing and proceed, to import the data with the [[Geo_Data_Wizard|Geo data wizard], or when you already have the data imported to select it based on an attribute of the data or to let the Tygron Platform automatically generate some data.
- the breach areas (only for the Flooding overlay
- ground water data
- constructions
For the constructions keep in mind that when the data is point data, it has to overlap two water level areas. Therefore make sure the point data is on the border of two water level areas.
- Weirs
- Culverts
- Pumps
- Sewer overflows; if chosen to generate automatically the sewer areas, the sewer overflows can also be automatically generated
Step 3
Step 4
Step 5
In step 5 you have to choose the result types (the different results which can be exported) you want to see after the calculation is done. Some overlays require a threshold value. Read below for the different result types to choose from and the threshold values. One of the overlays can be selected as the first overlay, which then will be visible as the parent Overlay. You can always later adjust the result types you want to see and calculate the Overlay again.
Step 6
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
| Result type | Unit | Description |
| BASE_TYPES | nominal value | Division of gridcells in water, land, water level areas, sewer areas that are connected to the sewer, breach areas and hydrological constructions |
| CHLORIDE | ||
| DIRECTION | Degrees | The direction of the flooding |
| EVAPORATED | m (mm)¹ | The amount of water that is evaporated |
| GPU OVERVIEW | ||
| IMPACTED_BUILDINGS | nominal value | Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M |
| LAST SPEED | m/s | The speed of the flooding at the last calculated timestep |
| MAX SPEED | m/s | The maximum speed of the flooding of all the calculated timesteps |
| NITROGEN | ||
| PHOSPHORUS | ||
| SEWER_LAST_VALUE | m (mm)¹ | The amount of water in the sewer storage at the last calculated timestep |
| SEWER_MAX_VALUE | m (mm)¹ | The maximum amount of water in the sewer storage of all the calculated timesteps |
| SURFACE_DURATION | s (min)¹ | The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M |
| SURFACE_FLOW | m3/m2 | Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2) |
| SURFACE_LAST_VALUE | m (mm)¹ | The water depth at the last calculated timestep |
| SURFACE_MAX_VALUE | m (mm)¹ | The maximum water depth of all the calculated timesteps |
| UNDERGROUND_FLOW | m³/m² | Total infiltration amount from the surface to groundwater |
| UNDERGROUND_LAST_STORAGE | ||
| UNDERGROUND_LAST_VALUE | m (mm)¹ | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep |
| UNDERGROUND_MAX_STORAGE | ||
| UNDERGROUND_MAX_VALUE | m (mm)¹ | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps |
| UNDERGROUND WATERTABLE | ||
| WATER_STRESS | m (mm)¹ | The maximum water depth during the simulation (almost the same as the SURFACE_MAX_VALUE, but at the terrain type water only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M) |
¹ the units between () are as displayed in the 3D client. If exported to GTiff the SI-convention is used: meters (m) and seconds (s).
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
The Water Balance panel shows the in- and outflow of water in m3. The Water Balance panel is also visible when clicking on the Debug info (see below). The water balance is made up of the following components (dependent on what is in the project):
Warnings
When the grid cell size is too large in combination with the project size, a warning pops up. This means that calculated results are not accurate. The solution to this is to change the grid cell size to a smaller number.
Debug Info
- Water areas:
If you click on the Debug Infom the Water Balance panel pops up.
Keys tab
The tab Keys refers to the settings for the water system (areas and constructions) that are adjusted by following the configuration wizard in the General tab. It is therefore generally not needed to change the keys in this tab, as this can be done also in the configuration wizard. However, below an explanation of the Keys for areas and buildings.
| Attribute | Unit | Description |
| Chloride | mg/m2 | |
| Nitrogen | mg/m2 | |
| Phosphorus | mg/m2 |
Attributes tab
| ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type |
| AVG_SURFACE_WATER | ||
| DESGIN_FLOOD_ELEVATION_M | m | |
| GROUND_BOTTOM_DISTANCE_M | m | |
| GROUND_WATER | ||
| IMPACT_FLOOD_THRESHOLD_M | m | maximum waterdepth around a building where after the building is assumed impacted shown in the IMPACTED_BUILDINGS result type |
| MAX_SPEED_MS | ||
| MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
| SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
| SHOW_DURATION_FLOOD_LEVEL_M | m | threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type |
| SUPERGRID | ||
| SURFACE_WATER_EVAPORATION_FACTOR | ||
| TIMEFRAMES | the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number). |
