Water Overlay
What are the Water Overlays
Configuration Wizard
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
| Result type | Unit | Description |
| BASE_TYPES | nominal value | Division of gridcells in water, land, water level areas, sewer areas that are connected to the sewer, breach areas and hydrological constructions |
| CHLORIDE | Description will be added when available | |
| DIRECTION | Degrees | The direction of the flooding |
| EVAPORATED | m (mm)¹ | The amount of water that is evaporated |
| GPU OVERVIEW | nominal value | Shows which GPU cluster calculated which part of the overlay |
| IMPACTED_BUILDINGS | nominal value | Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M |
| LAST SPEED | m/s | The speed of the flooding at the last calculated timestep |
| MAX SPEED | m/s | The maximum speed of the flooding of all the calculated timesteps |
| NITROGEN | Description will be added when available | |
| PHOSPHORUS | Description will be added when available | |
| SEWER_LAST_VALUE | m (mm)¹ | The amount of water in the sewer storage at the last calculated timestep |
| SEWER_MAX_VALUE | m (mm)¹ | The maximum amount of water in the sewer storage of all the calculated timesteps |
| SURFACE_DURATION | s (min)¹ | The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M |
| SURFACE_FLOW | m3/m2 | Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2) |
| SURFACE_LAST_VALUE | m (mm)¹ | The water depth at the last calculated timestep |
| SURFACE_MAX_VALUE | m (mm)¹ | The maximum water depth of all the calculated timesteps |
| UNDERGROUND_FLOW | m³/m² | Total infiltration amount from the surface to groundwater |
| UNDERGROUND_LAST_STORAGE | Description will be added when available | |
| UNDERGROUND_LAST_VALUE | m (mm)¹ | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep |
| UNDERGROUND_MAX_STORAGE | Description will be added when available | |
| UNDERGROUND_MAX_VALUE | m (mm)¹ | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps |
| UNDERGROUND WATERTABLE | Description will be added when available | |
| WATER_STRESS | m (mm)¹ | The maximum water depth during the simulation (almost the same as the SURFACE_MAX_VALUE, but at the terrain type water only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M) |
General Tab
Calculation Preference
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
| Attribute | Unit | Description |
| Chloride | mg/m2 | Description will be added when available |
| Nitrogen | mg/m2 | Description will be added when available |
| Phosphorus | mg/m2 | Description will be added when available |
Attributes tab
| ALLOWED_WATER_INCREASE_M | m | increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type |
| AVG_SURFACE_WATER | ||
| DESIGN_FLOOD_ELEVATION_M | m | |
| GROUND_BOTTOM_DISTANCE_M | m | |
| GROUND_WATER | ||
| IMPACT_FLOOD_THRESHOLD_M | m | maximum waterdepth on a cell which touches the building where after the building is assumed impacted, visualized in the IMPACTED_BUILDINGS result type |
| MAX_SPEED_MS | ||
| MIN_SLOPE | slope whereunder the pressure slope is assumed 0 | |
| SEWER_OVERFLOW_THRESHOLD | fraction of storage whereafter sewer overflows take place | |
| SHOW_DURATION_FLOOD_LEVEL_M | m | threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type |
| SUPERGRID | ||
| SURFACE_WATER_EVAPORATION_FACTOR | ||
| TIMEFRAMES | the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number). |
