Sun angle
Revision as of 12:26, 16 November 2018 by Godelief@tygron.nl (talk | contribs) (→Editing the Environment)
What is an Environment
The term Environment refers to the collection of properties of the 3D World surrounding the project area. These properties enhance the realism of the 3D World, without functionally affecting anything.
How does the Environment relate to the Tygron Platform
In the Tygron Platform, the Environment is the visualization of certain elements in and surrounding the 3D model. This includes different water and sky types, different building model styles and more. The appearance of these objects can be adjusted based on the user's preferences.
Most Environment settings can be edited in the bottom panel of the Editor. Template:Editor ribbon
How to Edit the Environment settings:
- Select Visuals in the ribbon header
- Select Environment in the ribbon bar
- Select Show Environment in the drop-down menu of the ribbon bar
- Notice that the settings have appeared in the bottom panel
Water
- Water Type with options: CANAL, SEA, DELTAVIEWER;
Sky
- Sky Type with options: DEFAULT, SUNNY, CLOUDED, EVENING;
Building style
- Building model style with options: TEXTURED, COLORED, PLAIN, DISCO, WIREFRAME;
Shadow
- Fixed Sun Angle
- Day Angle
- Position/Year Angle
Satellite map
- Satellite Brightness
