Groundwater Overlay
The groundwater overlay is an implementation of the Water model optimized for calculating the flow of underground watertables. This implementation focuses on water flowing at a low speed, and on the functioning of the water system without calamitous events such as breaches.
Use cases
The groundwater overlay can be used and is recommended when exploring the following use-cases:
- Modeling a static, low-speed water system
- Modeling the long-term effects of excessive rain or excessive drought on the water table
- Modeling the spread of chemicals through the underground, carried along by water
Preparing to use the overlay
To use the overlay, it is recommended that the project meets a number of prerequisites. Next, data can be prepared which define the functioning and flow of the water model. This includes a clear idea of what kind out output is desired. After that data is prepared, you can begin the actual steps of adding the overlay.
It is important to model a fully functional static water system for any relevant use of the groundwater overlay. After setting up the static water model, additional effects can be modeled to account for special circumstances. This has the added benefit of creating a control-state, to which results of modifications or calamities can be compared.
Prerequisites
- Your project has been loaded in with a high-resolution DEM. This can be configured during the new project wizard.
- Your project is large enough to account for edge effects. A buffer of at least 1km around your actual project area is recommended.
- The project's eventual use. The calculations will take longer than most other calculations in the Tygron Platform, so sessions with live interaction are discouraged.
Data
Before creating and configuring the overlay, it is best to prepare the data you wish to use in your model.
Geographical data
The following data needs to be prepared, so that it can be loaded in and used by the water model's calculations: Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist
Calculation properties
Consider the duration you want your simulation to last, and whether you wish to account for rainfall in your model. The following environmental data needs to be prepared, so that it can be configured and used by the water model's calculations: Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist
Result types
After the calculation completes, consider what kind of output is relevant to your use-case. The following result types can be considered, so that it can be configured and used by the water model's calculations: Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist Template:OverlayChecklist
Adding and configuring the overlay
- Check that your project sufficiently matches the stated prerequisites
- Make sure that you have prepared all data you wish to use
- Add the groundwater overlay to your project
- Start and follow the steps in the configuration wizard
- When the configuration wizard is completed, the overlay will automatically recalculate. (If it does not, select refresh grid.)
- When the recalculation has completed, you can inspect the results
Data analysis
When the calculation has completed, results of the calculation inspected by selecting the overlay in the session interface.
Overlay map
To check directly whether the model functions as expected, you can activate the overlay, and see the end-results directly. If multiple timeframes have been recorded, the results can be replayed, to see the progression of the results over time.
Water balance
Besides directly inspecting the results geographically, when verifying the functioning of a hydrological model it can be insightful to check the water balance. This option allows a net tally of where water ends up in the hydrological system.
Refining the model
Based on the results from the initial calculation, you can tweak your data to refine your model. You can update your relevant datasets, and then step through the configuration wizard again.
- Reopen the configuration wizard of the overlay
- In any step where you want to update your data, either change the individual values or clear, and reupload the data
- Skip through all steps which concern data you do not wish to change
- When you finish the configuration wizard, the overlay will automatically recalculate. (If it does not, select refresh grid.)
Every step where no data has changed can be skipped, and the dataset which has been uploaded can be reuploaded in the relevant step. Alternatively, you can do this directly by changing the relevant data in your project. For example, it is possible to directly change the attributes of constructions.
Saving the results
If the results of the calculation provide a proper baseline hydrological model, the result of the overlay can be saved as an inactive copy. This means that the overlay, including its direct settings and its results, are duplicated into a new overlay. The duplicate is then set to "inactive". This means the data in that overlay won't change as further changes are made. This means you can set up a new scenario in your original overlay, and after performing another calculation compare the results of the first and the second situation.
