Water Overlay
What are the Water Overlays
Configuration Wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Hydrological features
Water level area
WATER_LEVEL mNAP The water level for all water terrains in this water level area n/a
Sewer area
Breach
SURFACE_OVERRIDE mNAP The new terrain height at the location of the breach. n/a
INLET_CAPACITY m3 The maximum amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. Infinite
LOWER_THRESHOLD mNAP If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. None
UPPER_THRESHOLD mNAP If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. None
Note that a breach shares attribute names with the inlets, and that changing the attribute keys for breaches also affects the keys for inlets.
Inundation
INUNDATION_LEVEL mNAP The height of the water. n/a
Hydrological constructions
The water system can be enhanced with a number of hydrological constructions. These are constructions which effect water flow in specific cells, according to the parameters and rules of the constructions used. Constructions can be either line-based or point-based.
  • Line-based constructions
  • Point-based constructions
Culvert
CULVERT_HEIGHT mNAP The height of the culvert. (When set to a level lower than the terrain for either endpoint of it, the culvert's height is equal to the height of the (highest) terrain under either endpoint.) 0
Weir
WEIR_HEIGHT mNAP The height of the weir. n/a
Pump
Sewer overflow
SEWER_OVERFLOW mNAP The height of the bottom of the sewer, relative to the average terrain height of the connected sewer. Starting from this height, the water level in the sewer must exceed the height of the terrain at the location of the overflow in order for water to flow out. n/a
Inlet
LOWER_THRESHOLD mNAP If a lower threshold is set, water will only flow into the model through this inlet until the water level at the point of this inlet is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. None
UPPER_THRESHOLD mNAP If an upper threshold is set, water will only flow out the model through this outlet until the water level at the point of this inlet is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. None
Note that an inlet shares attribute names with the breaches, and that changing the attribute keys for inlets also affects the keys for breaches.
Miscellaneous constructions
Besides the constructions which directly influence the main water flow in the hydrological model, there are some constructions which interact with the model in other ways.
Sewered constructions
Water storage constructions
Crops and foliage
Chemical emitters
Water
Evaporation
Infiltration and storage
Result types
Each Water Overlay is a grid overlay showing results on the surface (flooding), sub-surface (groundwater), open water and sewer system. The following results are produced:
Result type Unit Description
BASE_TYPES nominal value Division of gridcells in water, land, water level areas, sewer areas that are connected to the sewer, breach areas and hydrological constructions
CHLORIDE Description will be added when available
DIRECTION Degrees The direction of the flooding
EVAPORATED m (mm)¹ The amount of water that is evaporated
GPU OVERVIEW nominal value Shows which GPU cluster calculated which part of the overlay
IMPACTED_BUILDINGS nominal value Constructions impacted by flood: the value from the function value indicator is assigned to a building if the water depth at a grid-cell surrounding the building exceeds the overlay attribute value IMPACT_FLOOD_TRESHOLD_M
LAST SPEED m/s The speed of the flooding at the last calculated timestep
MAX SPEED m/s The maximum speed of the flooding of all the calculated timesteps
NITROGEN Description will be added when available
PHOSPHORUS Description will be added when available
SEWER_LAST_VALUE m (mm)¹ The amount of water in the sewer storage at the last calculated timestep
SEWER_MAX_VALUE m (mm)¹ The maximum amount of water in the sewer storage of all the calculated timesteps
SURFACE_DURATION s (min)¹ The amount of time the water depth in a cell exceeds the value set in the overlay attribute value SHOW_DURATION_FLOOD_LEVEL_M
SURFACE_FLOW m3/m2 Total volume of water passed a grid-cell, scaled by the cell surface (grid cell-size^2)
SURFACE_LAST_VALUE m (mm)¹ The water depth at the last calculated timestep
SURFACE_MAX_VALUE m (mm)¹ The maximum water depth of all the calculated timesteps
UNDERGROUND_FLOW m³/m² Total infiltration amount from the surface to groundwater
UNDERGROUND_LAST_STORAGE Description will be added when available
UNDERGROUND_LAST_VALUE m (mm)¹ The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep
UNDERGROUND_MAX_STORAGE Description will be added when available
UNDERGROUND_MAX_VALUE m (mm)¹ The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps
UNDERGROUND WATERTABLE Description will be added when available
WATER_STRESS m (mm)¹ The maximum water depth of all the calculated timesteps (almost the same as the SURFACE_MAX_VALUE, but if the terrain type is water only a water depth is shown if the depth exceeds the overlay attribute value ALLOWED_WATER_INCREASE_M)
General Tab
Calculation Preference
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Breach Floor mNAP Modified terrain height, to simulate a breach in a levee.
Inundation level mNAP Initial water height, to simulate water present at the start of the simulation.
Attributes tab
ALLOWED_WATER_INCREASE_M m increment by which the water level on a water cell is allowed to increase before the depth is shown in the WATER_STRESS result type
AVG_SURFACE_WATER Description wil be added
GROUND_WATER Description wil be added
IMPACT_FLOOD_THRESHOLD_M m maximum waterdepth on a cell which touches the building where after the building is assumed impacted, visualized in the IMPACTED_BUILDINGS result type
MAX_SPEED_MS Maximum speed at which water is allowed to flow. As the maximum speed is set higher, the time per step of the calculation is reduced, increasing total time for the calculation to complete.
MIN_SLOPE slope whereunder the pressure slope is assumed 0
SEWER_OVERFLOW_THRESHOLD fraction of storage whereafter sewer overflows take place
SHOW_DURATION_FLOOD_LEVEL_M m threshold value of the amount of water on a grid cell that is used for the SURFACE_DURATION result type
SUPERGRID This marks an experimental feature which is currently under development and may result in unexpected behavior when activated.
SURFACE_WATER_EVAPORATION_FACTOR Description wil be added
TIMEFRAMES the number of intermediate (overlay) results you would like to see of the calculation. A timeframe is not the same as a timestep. A timeframe is an intermediate (overlay) result and can contain already a number of timesteps. The number of timesteps is based on the grid cell size and the speed of the flooding (see for more information the Courant number).
