Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Model connections
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation rate (m/day)
Line 1 Time when first period ends Rate of evaporation during first period
Line 2 Time when second period ends Rate of evaporation during second period
Ground water GeoTIFF
Template:GeoTIFFSpec
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
CRITICAL_INFRASTRUCTURE boolean Critical infrastructure Whether this construction is deemed a critical construction.
Chemical emitters/cleaners
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
1: Construction is impacted, and the critical function value is set to 0.
2: Construction is impacted, and the critical function value is set to 1.
UNDERGROUND_LAST_STORAGE m (mm)¹ Last The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep.
UNDERGROUND_LAST_VALUE m (mm)¹ Last The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep.
UNDERGROUND_MAX_STORAGE m (mm)¹ Maximum The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps.
UNDERGROUND_MAX_VALUE m (mm)¹ Maximum The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps.
Result child overlays
Currently, it is only possible to add result child overlays via the configuration wizard.
Calculations
Models
Surface height model
underground height model
Surface flow model
Underground flow model
Sewer model
Evaporation model
Surface evaporation model
Underground evaporation model
Chemical flow model
Line construction model
Point construction model
Polygon construction model
Model edge
General Tab
Calculation Preference
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
MIN_SLOPE The minimum slope required to account for the effect of gravity on the speed of the water. If the slope of the terrain is less than the minimum slope, the effect of gravity on the speed of the water is assumed to be 0.
SUPERGRID This marks an experimental feature which is currently under development and may result in unexpected behavior when activated.
