Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Model connections
Terrain height
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation (m)
Ground water GeoTIFF
Template:GeoTIFFSpec
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposer
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
UNDERGROUND_LAST_STORAGE m (mm)¹ Last The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep.
UNDERGROUND_LAST_VALUE m (mm)¹ Last The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep.
UNDERGROUND_MAX_STORAGE m (mm)¹ Maximum The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps.
UNDERGROUND_MAX_VALUE m (mm)¹ Maximum The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps.
Result child overlays
Calculations
Models
Surface model
Underground model
The underground model can be explicitly activated or deactivated by setting the GROUND_WATER attribute of the water overlay to the appropriate value.
Surface water infiltrates into the underground unsaturated layer. Water in the unsaturated layer is assumed to be spread equally across the entire unsaturated volume. Water then flows from the unsaturated zone into the saturated zone at the speed dictated by the underground terrain's GROUND_INFILTRATION_MD. For a given timestep, the distance the water travels is determined. The amount of water that flows from the unsaturated zone to the saturated zone is equal to the amount of water in a section of the unsaturated zone the height of which is equal to that distance. After water has been added to the saturated zone, the groundwater level (and thus the height of the saturated zone) is redetermined. The water in the unsaturated zone is redistributed uniformly across the unsaturated zone.
Sewer model
Evaporation model
Chemical flow model
Line construction model
Point construction model
Polygon construction model
Model border
Timestep formula
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
Surface infiltration formula
Surface infiltration capacity is calculated per cell.
I = min(Icon, Isurf)
  • I = The cell's infiltration capacity (m/day)
Δw = (Δt * Iund * Wunsat) / (GBDM - (Wsat/WSP))
Underground flow formula
Culvert formula
Weir formula
Pump formula
Overflow formula
Inlet formula
Surface evaporation formula
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
