Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Model connections
Terrain height
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation (m)
Ground water GeoTIFF
Template:GeoTIFFSpec
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposer
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
UNDERGROUND_LAST_STORAGE m (mm)¹ Last The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep.
UNDERGROUND_LAST_VALUE m (mm)¹ Last The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep.
UNDERGROUND_MAX_STORAGE m (mm)¹ Maximum The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps.
UNDERGROUND_MAX_VALUE m (mm)¹ Maximum The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps.
Result child overlays
Calculations
Models
Surface model
The surface water level is initialized based on hydrological features present in the project. For all Water terrains, water is placed on the surface of the world. The amount of water placed is such that the resulting water level in that location is equal to the WATER_LEVEL attribute of the Water level area in that location. If there is no water level area in that location, the water level is assumed to be so low that no water is created. Besides the water level areas, Inundation is added to the model. Water is placed in all locations where inundation is defined (regardless of the terrain type in that location, in contrast to the water level areas), such that the resulting height of the water inundating the land is equal to the inundation area's INUNDATION_LEVEL attribute.
On the surface, water can flow from one cell to an adjacent cell based on the relative heights of the water, the slope of the terrain, and the manning value.
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Chemical flow model
Line construction model
Point construction model
Polygon construction model
Model border
Timestep formula
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
Surface infiltration formula
Surface infiltration capacity is calculated per cell.
I = min(Icon, Isurf)
  • I = The cell's infiltration capacity (m/day)
Δw = (Δt * Iund * Wunsat) / (GBDM - (Wsat/WSP))
Underground flow formula
Culvert formula
Weir formula
Pump formula
Overflow formula
Inlet formula
Surface evaporation formula
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
