Water Overlay
What are the Water Overlays
Configuration wizard
Step 1
Step 2
- ground water data
- Weirs
- Culverts
- Pumps
Step 3
Step 4
Step 5
Step 6
Model connections
Terrain height
Weather
Rain and simulation time
Linear configuration
Custom configuration
| Rain and simulation CSV specification | |||||||||
| Data per line | Additional rainfall until specified moment | ||||||||
| Criteria | Time should always be greater than or equal to previous time Rain should never be negative | ||||||||
| First entry | Second entry | ||||||||
| Time (s) | Rain (m) | ||||||||
| Line 1 | Time when first period ends | Total rain during first period | |||||||
| Line 2 | Time when second period ends | Total rain during second period | |||||||
Evaporation
| Evaporation CSV specification | |||||||||
| Data per line | Rate of evaporation until specified moment | ||||||||
| Criteria | Time should always be greater than or equal to previous time Evaporation should never be negative | ||||||||
| Time (s) | Evaporation (m) | ||||||||
| Line 1 | Time when first period ends | Amount of evaporation during first period | |||||||
| Line 2 | Time when second period ends | Amount of evaporation during second period | |||||||
Ground water GeoTIFF
Subsidence
Hydrological features
Water level area
Sewer area
Breach
| SURFACE_OVERRIDE | m + datum | The new terrain height at the location of the breach. | n/a |
| INLET_CAPACITY | m3 | The maximum, total amount of water which can flow in or out through this breach. Water flowing back in the other direction replenishes the capacity. | Infinite |
| LOWER_THRESHOLD | m + datum | If a lower threshold is set, water will only flow into the model through this breach until the average water level on this breach is equal to or greater than the threshold. If the threshold is not set, the amount of water flowing in is not limited in this fashion. | None |
| UPPER_THRESHOLD | m + datum | If an upper threshold is set, water will only flow out the model through this breach until the average water level at the point of this breach is equal to or lower than the threshold. If the threshold is not set, the amount of water flowing out is not limited in this fashion. | None |
Inundation
Hydrological constructions
- Line-based constructions
Culvert
Weir
Pump
| PUMP_SPEED | m3/s | The speed at which water is pumped from the lower water level to the higher water level. | n/a |
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposer
Water
Evaporation
Infiltration and storage
Result types
| GPU OVERVIEW | nominal value | Maximum | Shows which GPU cluster calculated which part of the overlay. |
| IMPACTED_BUILDINGS | nominal value | Maximum | Constructions impacted by excess water. Constructions are considered impacted when the construction itself or an adjacent cell contains more water on the surface than configured in IMPACT_FLOOD_TRESHOLD_M. 0: Construction is not impacted |
| UNDERGROUND_LAST_STORAGE | m (mm)¹ | Last | The (effective) amount of water in the underground unsaturated zone at the end of the last calculated timestep. |
| UNDERGROUND_LAST_VALUE | m (mm)¹ | Last | The amount by which the groundwater table has risen above the initial groundwater level at the last calculated timestep. |
| UNDERGROUND_MAX_STORAGE | m (mm)¹ | Maximum | The maximum (effective) amount of water in the underground unsaturated zone across all calculated timesteps. |
| UNDERGROUND_MAX_VALUE | m (mm)¹ | Maximum | The maximum amount by which the groundwater table has risen above the initial groundwater of all the calculated timesteps. |
Result child overlays
Calculations
Models
Surface model
Water can also be added to or removed from the water model by line-based hydrological constructions. Based on the construction's underlying formula water can be added or removed to the cell indicated by the construction. Only that single cell will receive or lose the calculated amount of water.
When water flows onto a cell with a construction capable of storing water
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Chemical flow model
Line construction model
Point construction model
Polygon construction model
Model border
Timestep formula
Δt = Δx /umax
- Δt = computational timestep
- Δx = grid cell size
Surface water level formula
Surface flow formula
2D Saint Venant
- friction
- bed slope
- water pressure
Groundwater level formula
Surface infiltration formula
Surface infiltration capacity is calculated per cell.
I = min(Icon, Isurf)
- I = The cell's infiltration capacity (m/day)
Δw = (Δt * Iund * Wunsat) / (GBDM - (Wsat/WSP))
- Wsat = The amount of water stored in the saturated zone.
- Wunsat = The amount of water stored in the saturated zone.
- GBDM = GROUND_BOTTOM_DISTANCE_M (effectively available height in the underground model).
- WSP = WATER_STORAGE_PERCENTAGE.
Underground flow formula
Culvert formula
Weir formula
Pump formula
Overflow formula
Inlet formula
Surface evaporation formula
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
- Water areas:
Keys tab
| Breach Floor | m + datum | Modified terrain height, to simulate a breach in a levee. |
| Inundation level | m + datum | Initial water height, to simulate water present at the start of the simulation. |
Attributes tab
| MIN_SLOPE | ratio | The minimum slope required to account for the effect of gravity on the speed of the water. If the slope of the terrain is less than the minimum slope, the effect of gravity on the speed of the water is assumed to be 0. The ratio is the height over distance. |
| SUPERGRID | This attribute name is reserved for future functionality. Currently, this marks an experimental feature which is currently under development and may result in unexpected behavior when activated. | |
