Water Overlay
What are the Water Overlays
Configuration wizard
  • ground water data
    • Weirs
    • Culverts
    • Pumps
Model connections
Terrain height
Main article: Terrain height
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation (m)
Ground water GeoTIFF
Template:GeoTIFFSpec
Subsidence
Hydrological features
Water level area
Sewer area
Breach
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposers
Water
Evaporation
Infiltration and storage
Result types
1: Water level area
2: Land
3: Sewer
4: Breach
5: Hydrological construction
Result child overlays
Calculations
Models
Surface model
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Storage model
Chemical flow model
Model border
Timestep formula
Δt = Δx /umax
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
WHsurface = Wsurface / cell
WLsurface = WHsurface + Hsurface
  • WHsurface = The water height on the surface.
  • cell = Cell size.
  • Wsurface = The amount of water on the surface.
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
WHunderground = min( 0 , (Wsat / cell) / WSP )
  • WHunderground = The height of the saturated zone.
  • cell = Cell size.
  • Wsat = The amount of water in the saturated zone.
Surface infiltration formula
Δw = cell * min( 0 , WLsurface - Hsurface , Δt * Icon , Δt * Isurf)
  • WLsurface = The water level on the surface, relative to datum.
Δw = min( 0 , (Δt * Iund * Wunsat) / (GBDM - WHunderground) )
Underground flow formula
Culvert formula
Weir formula
Pump formula
Δw = min( 0 , cell * (WLlower - THlower) , PS )
  • WLlower = The water level at the lower end point, relative to datum.
  • THlower = The terrain height at the lower end point, relative to datum.
Overflow formula
Overflow can take place when:
Hsewer + SO - Hoverflow > 0
Actual overflow:
Inlet formula
When calculating as an inlet:
Δw = min ( 0 , Δt * cell * IQ , cell * min(0 , Tlower - WLsurface) , Cused - Ctotal )
When calculating as an outlet:
Δw = max ( 0 , Δt * cell * IQ , cell * max(0 , Tupper - WLsurface) , -Ctotal - Cused )
The used capacity is updated afterwards:
Cused (new) = Cused (old) + Δw
  • cell = Cell size.
  • Cused = The used amount of water capacity.
  • Ctotal = The INLET_CAPACITY attribute of the inlet.
  • WLsurface The water level on the surface, relative to datum.
  • IQ = The INLET_Q attribute of the inlet.
  • Tlower = The LOWER_THRESHOLD attribute of the inlet.
  • Tupper = The UPPER_THRESHOLD attribute of the inlet.
Surface evaporation formula
Δw = min( 0 , WLsurface - Hsurface , Δt * Eweather * Eoverlay )
  • Eoverlay = The SURFACE_WATER_EVAPORATION_FACTOR.
Evaporation capacities:
Csat = cell * max( 0 , WHunderground + Rtop - GBDM )
Cunsat = min( Wunsat , (Rtop*Wunsat/(GBDM - WHunderground)) )
Cunsat = 0 if Rtop = 0
Cunsat = 0 if GBDM - WHunderground = 0
Actual evaporation:
Δwunsat = min( 0 , Δt * Eweather * Etop , Cunsat )
Δwsat = min( 0 , (Δt * Eweather * Etop) - Δwunsat , Csat )
  • Δwsat = The actual evaporation which takes place from the saturated zone.
  • Δwunsat = The actual evaporation which takes place from the unsaturated zone.
  • cell = Cell size.
  • Cunsat = The amount of evaporation that can take place from the saturated zone.
  • Wunsat = The amount of water in the saturated zone.
  • Rtop = The ROOT_DEPTH_M of the construction if present, the ROOT_DEPTH_M of the surface terrain otherwise.
Calculation time impact
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
Keys tab
Attributes tab
