Water Overlay
Revision as of 13:00, 7 February 2019 by Rudolf@tygron.nl (talk | contribs)
What is the Water overlays
Water flow is affected by properties of the terrain across which it flows, including the terrain height and the properties of the underlying terrain type.
Variants
How to use the Water overlays
To use any variant of the overlay, it is recommended that you ensure the project meets a number of prerequisites. Next, it is recommended to prepare all data related to the hydrological model, which defines the functioning and flow of the water. Included in this preparation is a clear idea of what kind of output is desired. After these preparations have been made, creation and configuration of the overlay can begin.
Prerequisites
Configuration
Configuration wizard
Template:Editor ribbon
Step 1: Weather
Step 2: Water system
Step 4: Interaction
Step 5: Output overlays
Step 6: Input overlays
Manual configuration
Grid cell size
Main article: Grid overlay
Calculation preference
Weather (simulation time, rainfall, evaporation)
Main section: Weather
Ground water
Main section: Ground water
Subsidence
Main section: Subsidence
System visualization
Active in simulation
Result type
Main section: Result type
Legend
Keys
Main section: Data
Main section: Attributes
Results
Model connections
Terrain height
Main article: Terrain height
Template:GeoTIFFSpec
Weather
Rain and simulation time
Linear configuration
Property Unit Description
Custom configuration
Rain should never be negative
First entry Second entry
Time (s) Rain (m)
Evaporation
Evaporation CSV specification
Time (s) Evaporation (m)
Ground water
Subsidence
Data
Water level area
Sewer area
Breach
The breach can grow over time, based on its initial width and the critical speed at which water may flow. If a BREACH_WIDTH is defined, the breach's polygon is intersected with a circle emanating from the centerpoint of the polygon. It is only in that intersection, dubbed the "active breach" that the terrain height is considered lowered to the BREACH_HEIGHT. The radius of the circle defining the intersection will expand when the water flowing in from the external water body exceeds the BREACH_SPEED. Water flowing in the hydrological model across the breach's surface without explicitly entering or leaving the hydrological model does not "count" for the critical speed. All cells in the active breach are considered directly adjacent to the external water body.
Inundation
Hydrological constructions
  • Line-based constructions
  • Point-based constructions
Culvert
Weir
Pump
Sewer overflow
Inlet
Sewered constructions
Water storage constructions
Porous constructions
Crops and foliage
Critical structures
Chemical emitters/decomposers
Water
Evaporation
Infiltration and storage
Settings
Result type
1: Water area
2: Land
3: Sewer
4: Water object
5: Breach Area
6: Active Breach
Result child overlays
Keys
The water model calculation's rely on a number of calculation-wide parameters. These parameters are available as attributes of the water overlay and can be modified as such.
Calculations
Models
Surface model
Underground model
Rain model
Evaporation model
Surface evaporation model
Underground evaporation model
Sewer model
Storage model
Chemical flow model
Model border
Timestep formula
Δt = Δx /umax
Where:
  • Δt = computational timestep
  • Δx = grid cell size
Surface water level formula
Where:
Surface flow formula
2D Saint Venant
  • friction
  • bed slope
  • water pressure
Groundwater level formula
WHunderground = Wsat / WSP
Where:
Surface infiltration formula
Infiltration capacities:
Cwater = Wsurface
Ctop = max( Icon, Isurf )
Actual infiltration:
Δw = min( Cwater , Δt * Ctop)
Where:
S = Wunsat/Hunsat
Δw = Cinf * S
Where:
Underground flow formula
Where:
  • cell = Cell size.
Culvert formula
Weir formula
Pump formula
Δw = min( Wlower , Δt * PS )
Where:
Overflow formula
Overflow can take place when:
Hsewer + SO - Hoverflow > 0
Actual overflow:
Inlet formula
If a Tlower is defined:
If a IQ is defined:
Cspeed = Δt * IQ
If a Ctotal is defined:
Cincap = Cused - Ctotal
If a IQ is defined:
Cspeed = Δt * IQ
Coutcap = -Ctotal - Cused
Where:
  • cell = Cell size.
Surface evaporation formula
Evaporation capacities:
Δw = Δwunsat + Δwsat
Where:
Computational structure
Order of operations
  • Rain
  • Building storage
  • Sewer inflow
  • Surface evaporation
  • Underground infiltration
  • Surface infiltration
  • Exfiltration
Calculation time impacts
General Tab
Calculation Preference
Δt = Δx /umax
Grid cell size
Refresh Grid
Export Grid File
Save Overlay result
Show Water Balance
Warnings
Debug Info
  • Water areas:
  6. Langevin, C.D., Hughes, J.D., Banta, E.R., Niswonger, R.G., Panday, Sorab, and Provost, A.M. (2017) ∙ Documentation for the MODFLOW 6 Groundwater Flow Model: U.S. Geological Survey Techniques and Methods, book 6, chap. A55 ∙ p 31 ∙ found at: https://doi.org/10.3133/tm6A55 (last visited 2019-02-04)
