Hydrological attributes of terrains (Water Overlay)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
| FLOOR_HEIGHT_M | m | Floor height (m) | The height of a floor in a construction. Additionally each section of a construction can have a different amount of floors. |
| WATER_MANNING | s/(m1/3) | Surface | The Gauckler–Manning coefficient of the construction. |
| SUBSTANCE_A | x/m²s | The amount of substance A created per second per m² in this location. | |
| SUBSTANCE_B | x/m²s | The amount of substance B created per second per m² in this location. | |
| SUBSTANCE_C | x/m²s | The amount of substance C created per second per m² in this location. | |
| SUBSTANCE_D | x/m²s | The amount of substance D created per second per m² in this location. |
