Hydrological attributes of terrains (Water Overlay)
Terrains in a project have a number of hydrological properties which can influence the flow of water in a project. Because there is always both surface and underground terrain defined for the entirety of the project area, all cells are affected by all properties of terrains, unless a construction is present with overwriting values.
WATER_STORAGE_PERCENTAGE fraction Underground The percentage (as a fraction) of the underground volume which can be filled with water. A lower percentage means the underground will be able to store less water, and the saturated zone will rise higher with the same amount of water in the underground layer.
WATER_MANNING s/(m1/3) Surface The Gauckler–Manning coefficient of the construction.
SUBSTANCE_A x/m²s The amount of substance A created per second per m² in this location.
SUBSTANCE_B x/m²s The amount of substance B created per second per m² in this location.
SUBSTANCE_C x/m²s The amount of substance C created per second per m² in this location.
SUBSTANCE_D x/m²s The amount of substance D created per second per m² in this location.
Template:WaterOverlay attribute nav
