Water Overlay Wizard
![](/w/images/6/6e/FloodingWizardIntroduction1.jpg)
The configuration wizard is a special interface which helps to guide the configuration of the overlay. Across multiple steps, it progresses through each type of Data which can be configured, along with the most important attributes of the overlay.
Each of the water overlay variants has a configuration wizard which helps the user with configuring the overlay. The general structure of the wizard is the same for all variants, with the exception that for flooding overlays a step for configuring a breach area is included and for the Groundwater (Overlay) a step for configuring an aquifer area is included.
Step 1: Weather
![](/w/images/3/35/GroundWaterOverlayWeatherEvent1.jpg)
Step 2: Water system
![](/w/images/4/4a/FloodingOverlaySetUpWaterSystem1.jpg)
The water system is the most complex step of the configuration and contains a multitude of substeps to configure all geographical data. Its various components can be configured in the following order:
- Breach (flooding overlays only): A breach area, a location where an (uncontrolled) inflow of water takes places.
- Water areas: Water level areas, defined regions in which a specific water level is maintained. It is also possible to have the wizard generate a single water level area for the entire project area.
- Ground water: Ground water, the height of the underground saturated by water relative to datum. A GeoTIFF can be imported.
- Sewers: Sewer areas, the broad definitions for where what kind of sewers exist. It is also possible to have the wizard generate sewer areas based on the neighborhoods in the project area.
- Inundation areas: Inundation areas, definitions of water on the surface, in the form of inundated land. It is also possible to have the wizard generate a single inundation area covering the entire project area.
- Aquifer areas (groundwater overlays only): Aquifer areas, definitions for transmissivity or hydraulic conductivity of the underground layer.
- Weirs: Weirs, minor barriers in the water flow.
- Culverts: Culvert (Water Overlay)|Culverts]], tunnels which form direct connections between two locations.
- Pumps: Pumps, structures which move water from a lower to a higher location.
- Inlets: Inlets, structures which add or remove water.
- Sewer overflows: Sewer overflows, points where water from sewers can flow back onto the surface.
All of the above components can be imported or connected to the hydrological model.
Breach Area
Water Areas
Ground Water
Sewers
Inundation Areas
Aquifer Areas
Weirs
Culverts
Pumps
Inlets
Sewer Overflows
![](/w/images/7/72/FloodingOverlayHydrologiCoefficients1.jpg)
- Surface terrain: For the surface terrains, attributes can be adjusted directly.
- Underground terrain: For the underground terrains, attributes can be adjusted directly as well.
- Constructions: For constructions, the wizard links to the function values editing screen, and will open it the "WATER" filter for the values to display.
Surface terrain
Underground terrain
Constructions
Step 4: Interaction
![](/w/images/6/6d/FloodingOverlayWizardInteraction1.jpg)
Step 5: Output overlays
![](/w/images/8/8b/FloodingOverlayWizardOutputOverlays1.jpg)
Multiple Result types are available. In the wizard multiple result types can be selected. One result type (indicated with the "First" checkbox) will be the main overlay's result type. The other selections will become Result child overlays. Relevant attributes can be modified as well, if they are related to selected result types.
Step 6: Input overlays
![](/w/images/0/08/FloodingOverlayWizardInputOverlays1.jpg)
To gain more insight into the data used by the model, you may opt to add one or more input overlays as well. These add Average Overlays configured for the geographical display of attribute values relevant for the calculation of the water model.
