Terrain water manning (Water Overlay)
Revision as of 12:09, 20 June 2019 by Jorn@tygron.com (talk | contribs)
Manning's n (terrain)
Terrains have an inherent "roughness", affecting the flow of water across its surface, which is expressed by the Gauckler–Manning coefficient or, in short, Manning's value (n).
- The default values for this attribute are derived from online accessible databases[1] and are readily adjusted by the user.
- If a construction is present on the terrain, the WATER_MANNING value of the construction is used instead.
- Only terrains of type 'surface' have an assigned WATER_MANNING.
- ↑ WikiEngineer (2008-2011). Manning Roughness Coefficients. Retrieved from: http://wikiengineer.com/Water-Resources/ManningRoughnessCoefficients
