DPRA Heat Module
Revision as of 13:53, 12 September 2019 by Frank@tygron.nl (talk | contribs) (Results)
We are working on a new heat module in accordance the new Dutch DPRA standards. This module is still under construction, as is the documentation, however a Beta version of the module is available on the Preview server for our partners.
Configuration
The Heat DPRA module can be configured using the Heat Overlay configuration wizard.
For the configurable model attributes, see Heat model attributes.
Results
With a Heat Overlay a user can generate a physiological equivalent temperature overlay, along with other (intermediate) overlay results. The Heat Overlay wizard allows users to select which results should be generated. For further information on the possible results, see result types.
Theory
The formula's and calculation models are documented here.
