Model attributes (Heat Overlay)
The heat overlay's model calculations depend on a number of calculation-wide parameters. These parameters are available as attributes of the heat overlay and can be modified as such.
| DAILY_AVG_RADIATION | Wm-2 / hr | The average of amount of sun radiation per hour per square meter for this day, measured at a weather station. | 340 | ||
| DAILY_AVG_WIND_SPEED | m/s | The daily average wind speed measured at a weather station at the height of 10 meters above ground. | 3 | ||
| DAILY_TEMPERATURE_MAX | °C | Maximum temperature measured at a weather station. | 34 | ||
| DAILY_TEMPERATURE_MIN | °C | Minimum temperature measured at a weather station. | 19 | ||
| DATES | time in milliseconds | Dates define the amount of timeframes and are used to define the day and time for calculating sun angles. | 1375444800000 | ||
| EXCLUDE_BUILDINGS | boolean | Whether the results of buildings should be excluded from the avg sky-view and PET results. | 1 | ||
| EXCLUDE_WATER | boolean | Whether the results at the location of water should be excluded from the avg sky-view and PET results. | 1 | ||
| EXCLUDE_FOLIAGE_HEIGHT_M | m | Whether the area directly below foliage (e.g. Trees higher then this value) should be excluded in calculating the average sky view. | 1.2 | ||
| FOLIAGE_AREAS | boolean | Whether to use foliage data from Areas instead of the calculated foliage decks from functions with a foliage crown factor. | 0 | ||
| HOURLY_HUMIDITY | percentage | The relative humidity of the air at this hour, measured at a weather station. | 60 | ||
| HOURLY_RADIATION | Wm-2 / hr | The amount of Sun radiation this hour, measured at a weather station. | 700 | ||
| HOURLY_TEMPERATURE | °C | The temperature at this hour, measured at a weather station. | 33 | ||
| MAX_SHADOW_DISTANCE | m | 100 to 1000 | The maximum length of a shadow. | 500 | |
| SUN_ALTITUDE | angle (0-90°) | The sun angle up from the horizon. | 49.71 | ||
| SUN_AZIMUTH | geo angle (0-360°) | -1.7976931348623157E308 to 1.7976931348623157E308 | The angle of the sun along the horizon. | 140.03 | |
| SUN_DAILY_MOTION | factor | A factor to account for the sun moving across the sky throughout the day. | 0.11 | ||
| WIND_DIRECTION | geo angle (0-360°) | -1.7976931348623157E308 to 1.7976931348623157E308 | The wind direction viewed from above, with 0° corresponding to north, and increasing in a clockwise fashion. | 0 | |
| WIND_SPEED | m/s | The wind speed measured at a weather station at the height of 10 meters above ground. | 3 | ||
| WIND_DECLINE_ANGLE | Degrees | This angle determines how the wind flows down around objects. | 90 |
- The model relies on a number of attributes which can be measured by measure stations. For any given project, it is recommended to find data from a (reference) weather station applicable to the project area, and use those values as parameters for the Heat Module calculations.
- When the DATES attribute is configured for multiple timeframes, the Hourly, Sun, and Wind attributes should have an equal amount of entries. When using the Heat Overlay configuration wizard, the necessary entries are created automatically.
