UHI formula (Heat Overlay)
The Urban heat island effect is calculated using the following formula:
Formula Decomposition
The formula has two parts, the factor and the temperature effect:
UHImax = factor · temperature_effect
Factor
The factor is influenced by the sky view factor and the vegetation fraction, both ranging from 0 to 1. When both are low, i.e. barely any sky and no vegetation, the factor is near 2. When both are high, i.e. no surrounding buildings and a lot of vegetation, the factor is near 0.
Temperature effect
The Urban heat island temperature effect is calculated as:
Daily average global radiation
The S is calculated as followed:
where,
  • is the daily average global radiation in W/m2/hr
  • is the air heat capacity in J. We use a value of 1007 J.
  • is the hourly temperature measured at the station
  • is the calculated air density in kg/m3;
  • is the gas constant for dry air. We use a value of 287.058 J/(kg·K)
