Max water bottom m (Water Overlay)
Revision as of 14:00, 15 October 2019 by Frank@tygron.nl (talk | contribs)
Attribute Unit Description
MAX_WATER_BOTTOM_M m + datum The maximum height for the bottoms of water terrains. Any water terrain with a bottom at a higher datum height has its bottom lowered to this value.
  • This functionality can be used to resolve some instances where an irregular bottom ofwaterways would inhibit the proper flow of water. Because in slow-moving models there is little difference to to deep or shallow water if the amount of water flowing to adjacent cells is minimal, setting this attribute to a sufficiently low value can allow water to flow uninhibited by artifacts in the height of the waterway's bottom.
