Result types (Heat Overlay)
Revision as of 09:12, 16 December 2019 by Rudolf@tygron.nl (talk | contribs)
The Heat Module of a Heat Overlay performs complex calculations and can generate multiple types of results per timeframe. A timeframe in the Heat Overlay correspond to a date and time for which a result will be calculated. This date and time will be relative to the project's time zone.
List of Result Types
Icon Result type Unit Display mode Description
BOWEN_RATIO ratio Date-Time The initial bowen ratio of buildings and terrain. Differs for water terrain based on day and night.
FOLIAGE m Start The initial and optional calculated foliage height, depending on the source of the foliage height.
PET °C Date-Time The calculated physiological equivalent temperature.
PET_RELATIVE °C Date-Time The calculated PET temperature subtracted by the calculated atmospheric temperature
SHADE boolean Date-Time Indicates whether a cell is in the shade or not based on sun ray calculations.
SKY_VIEW Start The calculated sky view factor.
SKY_VIEW_AVG Start The calculated average of individual calculated sky view factors.
TEMPERATURE_ATMOSPHERE °C Date-Time The calculated atmospheric temperature, based on the UHI, sun motion factor and the measured temperature.
UHI °C Date-Time The calculated urban heat island effect.
VEGETATION Date-Time The fraction of vegetation per square meter.
VEGETATION_AVG Date-Time The calculated average vegetation based on the cells' individual vegetation fraction.
WIND_SPEED m/s Date-Time The wind speed calculated for the height of 1.2 meters above ground.
Result types can differ in the kind of data they display and in what way that data is recorded. A result type can be monitoring the data in one of the following ways:
  • Start: The data is determined at the start of the simulation, and does not change over the course of multiple time steps.
  • Date-Time: The data is dependent on the timestep, which corresponds to a date and time. In case the Average timeframe option is selected, the last timeframe will present the average values of all previous timesteps for that particular Result Type.
