How to create an urban area using parametric design
Revision as of 10:00, 8 January 2020 by Rudolf@tygron.nl (talk | contribs)
Urban areas can be created using parametric design. Especially broad and general features can easily be created, with details added manually.
How to create an urban area using parametric design.:
  1. Determine the area where an urban area is to be created.
  2. Manually create the network of roads for the urban environment.
  3. Create a parametric design, configured with the Function most prevalent in the urban area.
  4. Draw the extent of the design over the desired area.
  5. Verify that the generated selections look appropriate, and apply the design.
  6. Manually select any constructions which should be of a different Function, and change their Function.
  • It is only possible to create a single type of function at a time when using parametric designs.
