Parametric Design
(Redirected from Parametric design)
Parametric Designs in relation to other Actions
A parametric design in the Tygron Platform can be used to automatically place elements of a spatial plan, such as Buildings, roads, green, and waterways in a certain layout for a given area. Requirements for the design can be configured using a set of parameters. These describe the rules and boundaries, as well as attributes for the created Buildings and Terrain Types. The algorithm behind the parametric design tries to comply to the provided requirements as much as possible when generating a design.
Configuration
A generated parametric design
A parametric design consist of the following seven elements which make up the spatial plan:
  • Roads
  • Water
  • Parking
  • Side walk
  • Building, up to 6 different plot designs
  • Garden
  • Public Green
For each of the elements a Function or Terrain Type can be chosen. Other parameters such as the width of the roads and the number of floors for the building can be adjusted. To generate the design, the amount in percentages of each function (with the exception of the side walk function) can be adjusted with a slider. Additionally, when the design has multiple building plot designs, the percentual distribution between these plot designs has to be specified.
The general strategy is to provide a selection area and a design type. Then use the sliders to set the percentage per function you would like to see in the design. After the design is generated, notice in the pie chart in the bottom panel the actual percentage of each function that is determined by the parametric design algorithm. When you are happy with the generated design, the plan can either be saved to the Current Situation, added as a Measure or constructed in Future Design.
  • Save to current: a Test Run is not started. Instead it is applied to the Current Situation. This method is not easily reversed.
  • Especially for road aligned designs it can sometimes be needed to add a road to the area manually in advance, in order to get proper road alignment. The Tygron Platform only adds roads within an area, never on the edge, to avoid adjacent road placement.
    • Roads already present in the area of the Parametric Design before generating the design also count towards the percentage of roads for the design in the area. The more roads are present beforehand, the fewer additional roads are generated to reach the target percentage.
