Waterwijzer Overlay
The waterwijzer overlay provides the loss of earnings of crops based several input parameters. These loss of earnings are currently calculated by the Waterwijzer Landbouw module, which is described here.
Usage
The Waterwijzer Overlay results can be used to:
- Calculate the loss of earnings based on existing crops for currently known highest and lowest ground water levels.
- Calculate the loss of earnings for crops when using different ground water level management strategies simulated by a Ground Water Overlay or a Subsidence Overlay.
- Determine the best type of crop per parcel given the highest and lowest ground water levels and type of soil.
Considerations
The Waterwijzer Overlay calculates loss of earnings for agriculture crops based on:
- A climate scenario;
- A weather station;
- Type of soil;
- Type of crop;
- Highest and lowest (averaged) ground water levels;
- The irrigation parameter, which in the Waterwijzer tool is active for a subsection of the crops, is currently not taken into account.
Module
A Waterwijzer Overlay can be configured by opening the Waterwijzer Overlay Wizard. More in-depth information can be found under each of the categories below.
Template:Waterwijzer Module buttons
Result types
The overlay offers the following result types:
| Result type | Unit | Description |
| DAMAGE_DRY | % loss of earnings | The loss of agricultural earnings for drought scenarios, for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. When the water levels in the ground are too low, roots are unable to absorb enough moisture. |
| DAMAGE_WET | % loss of earnings | The loss of agricultural earnings due to high ground water levels, for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. When the water levels in the ground are too high, subsurface air is replaced by water and plant roots cannot obtain enough oxygen. |
| DAMAGE_INDIRECT | % loss of earnings | The loss of agricultural earnings due to indirect causes, for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. Indirect causes relate to the type of soil, type of crop and water levels.
Taken into account are:
| DAMAGE_SALT | % loss of earnings | The loss of agricultural earnings due to salt water irrigation or salt water seepage, for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. Too much salt concentration leads to a reduction of water absorption of plant roots, increased toxicity, problems with nutrients absorption and decreased root growth. |
| DAMAGE_TOTAL | % loss of earnings | The total loss of agricultural earnings for a particular crop, using the highest and lowest ground water levels adjusted by subsidence. These earnings are calculated by the Waterwijzer Landbouw api. |
