Waterwijzer Module
The Waterwijzer module calculates the result for the following question:
I want to know the expected loss of earnings for agriculture based on the crop, soil type and local ground water levels, given a climate scenario and the expected weather.
Considerations
The Waterwijzer Overlay communicates with the Waterwijzer API to calculate the loss of earnings for agriculture crops based on the following parameters:
Concept
  1. User generates a project for an area in the Netherlands using the Tygron Platform.
    • The Dutch BRP geo-plugin retrieves the known agriculture plots. Each agriculture plot has an identification number for the type of plot, which is stored in the BRP_CODE attribute.
    • The Dutch BRO geo-plugin retrieves the known soil types, stored as underground terrain. The simplified BOFEK_ID is configured by default for each terrain type of these terrain.
  2. User adds a Waterwijzer Overlay and configures:
    1. The climate scenario and weather station are configured using the Waterwijzer Overlay Wizard
    2. The ground water levels can also be configured using the Waterwijzer Overlay Wizard. These ground water levels can be provided as:
  3. User triggers the calculation of the overlay. The Waterwijzer Module sends the data to Waterwijzer API and receives data on loss of earnings.
  4. The Waterwijzer module then stores the grid data under following result type overlays, categorized as:
    • Dry: low water levels cause crops to dry out;
    • Wet: high water levels cause crops' roots to suffocate;
    • Indirect: Indirect causes, related to combinations of crop, soil, weather and water levels
    • Salt: salt water irrigation causes damage to crops;
    • Total: the sum of the previous four categories.
Calculation
The Waterwijzer Overlay is a Grid Overlay. The project area is rasterized into grid cells, each containing a value for:
  • the type of crop, identified by their BRP Code.
  • the soil: BOFEK_ID
  • the lowest (average) ground water depth: distance to surface, from geotiff or result overlay.
  • the highest (average) ground water depth: distance of surface, from geotiff or result overlay.
The climate scenario and weather station are a single value for each grid cell.
Each unique combination of crop, soil, ground water depths, climate scenario and weather station leads to four loss of earning values, one for each category, which were described above. To make it more efficient, we send each combination only once. The ground water levels have the most variance. However, the Waterwijzer API interprets the groundwater levels with a precision of 0.1 meter.
Once the loss of earnings have been send back for each combination, we process all grid cells and store it's loss of earnings, depending on the result types configured for the Waterwijzer Overlay.
  • Currently we round the ground water values to the nearest value based on the 0.1 meter precision. However, in the near future we will replace this with bi-linear interpolation between the 4 combinations of floored and ceiled ground water levels, which is similar to the calculation done by the Waterwijzer's standalone application.
