Surface infiltration formula (Water Overlay)
Revision as of 12:03, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
First, the infiltration capacities are calculated:
if a construction is present
if no construction is present
Then the actual infiltration:
Where:
  • = The surface infiltration which takes place.
  • = Computational timestep.
  • = The amount of infiltration that can take place based on the amount of water on the surface.
  • = The amount of infiltration that can take place based on the infiltration values present.
  • = The amount of water (the water column) on the surface.
  • = The GROUND_INFILTRATION_MD of a construction on a specific cell (if present).
  • = The GROUND_INFILTRATION_MD of the surface terrain type. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
Related
Surface water level formula
Groundwater level formula
Models
Surface model
Underground model
Infiltration model
Substance flow model
