Surface infiltration formula (Water Overlay)
Revision as of 12:06, 14 August 2020 by Rudolf@tygron.nl (talk | contribs)
First, the infiltration capacities are calculated:
if a construction is present
if no construction is present
Then the actual infiltration:
Where:
- = The surface infiltration which takes place.
- = Computational timestep.
- = The amount of infiltration that can take place based on the amount of water on the surface.
- = The amount of infiltration that can take place based on the infiltration values present.
- = The amount of water (the water column) on the surface.
- = The GROUND_INFILTRATION_MD of a construction on a specific cell (if present).
- = The GROUND_INFILTRATION_MD of the surface terrain type. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
Related
- Formulas
- Surface water level formula
- Groundwater level formula
- Underground infiltration formula
- Models
- Surface model
- Underground model
- Infiltration model
- Substance flow model
