Ground bottom flow formula (Water Overlay)
Revision as of 09:04, 28 August 2020 by Frank@tygron.nl (talk | contribs)
Underground seepage from outside the project area is calculated per grid cell.
The water level change due to seepage is calculated using the following formula:
The external seepage head is variable over time by the introduction of hv,t:
Finally, the actual amount of water seeping into the ground from the bottom is calculated as followed:
Where:
  • = The water level change due to seepage, in meters.
  • = Computational timestep in seconds.
  • = Ground water head in the grid cell.
  • = additional ground water level (or head) of the external zone causing the seepage at time t, in meters
  • = constant ground water level (or head) of the external zone causing the seepage, in meters
  • = additional variation of seepage head over time
  • = resistance of the separating layer in days
  • = water storage fraction of the soil
  • = seeped in water in m
  • and can both be provided as spatially variable values.
  • can be provided as a set of values, variable over time.
  • A seepage head lower than the water level in the project is also allowed, resulting in water seeping out to a region outside the project area.
