Ground bottom flow formula (Water Overlay)
Revision as of 11:53, 2 September 2020 by Rudolf@tygron.nl (talk | contribs)
Underground seepage from outside the project area is calculated per grid cell.
The water level change due to seepage is calculated using the following formula:
Δsx,y=hd(t)hx,ycx,yΔt246060
The external seepage head is variable over time by the introduction of hv,t:
hd(t)=hcx,y+hv,t(t)
Finally, the actual amount of water seeping into the ground from the bottom is calculated as followed:
Δwx,y=Δsx,yws
Where:
  • hcx,y and cx,y can both be provided as spatially variable values.
  • hd(t) can be provided as a set of values, variable over time.
  • A seepage head lower than the water level in the project is also allowed, resulting in water seeping out to a region outside the project area.
