Ground infiltration formula (Water Overlay)
Revision as of 13:21, 2 September 2020 by Rudolf@tygron.nl (talk | contribs)
S = Wunsat/Hunsat
Finally, calculate the actual amount of water infiltrating.
Δw = Cinf * S
Where:
Related
Groundwater level formula
Surface infiltration formula
Seepage formula
Models
Underground model
Infiltration model
Substance flow model
