Address
Revision as of 13:03, 28 September 2020 by Reijn@tygron.com (talk | contribs)
Address
An address is a specific reference to the whereabouts and location of a construction, given to it and registered by the municipality. The set up of addresses is built on the assumption that buildings are fixed
An overview of different addresses
Addresses in the Tygron Platform
The Tygron Platform, distinguishes two primary catergories in the attribute registration of addresses to a constrction. The first one is the name of the constuction in the 3D model, each construction is seen as a separate polygon in the Tygron Platform. Thus this attribute only describes the building itself. The seccond one is/are the address(es) used for the construction. When there are multiple adresses registered to one building this will also be repreoduced by the Tygron Platform. The addresses can be is the automatically generated from a building regstration databases. In the Netherrlands these databases are: BAG and TOP10NL. These databases are holding both the registration of addresses and buildings in the Netherlands. When generating a construction from the BAG database, simultaneously the same address will also add a BAG_ID to its attributes, this BAG ID is unique per address.
Generic uses of address
Buildings in the Tygron Platform are three-dimensional polygon objects capable of holding a wide variety of attributes. Each construction is registered to the grid with only one specific building name, this can, for example, be the address or range of addresses registered to the building. Therefore the multiple different addresses that are registered to one building (e.g. a flat) all hold the same constrcution details. As seen in the overview of different addresses, the various properties within one address are registrated using the zipcode + house number + letter addition (if available).
In the attributes of a building, an overview of the different addresses can be found. The different addresses registered to a construction by the Tygron Platform are still adjustable after the generation of the 3D model. The funciton type of an address can be defined using string format.
