Hi ground water result type (Subsidence Overlay)
Revision as of 13:24, 29 October 2020 by Rudolf@tygron.nl (talk | contribs)
Icon | Result type | Unit | Mode | Description |
HI_GROUND_WATER | m | Total | The distance between the ground surface and the highest ground water level. This number is lower than that of the lowest ground water level. A positive value means the ground water is below the surface of the land. A negative value would theoretically mean the ground water has risen above the surface of the ground. |
