Ground infiltration formula (Water Overlay)
Revision as of 17:19, 4 December 2020 by Frank@tygron.nl (talk | contribs)
Hunsat=HsurfaceWLunderground
S=Wunsat/Hunsat
Cinf=min(Hunsat,ΔtIund)
Finally, calculate the actual amount of water infiltrating.
Δw=CinfS
Where:
Related
Groundwater level formula
Surface infiltration formula
Underground seepage formula
Models
Underground model
Infiltration model
Tracer flow model
