Radial well aquifer benchmark (Water Module)
Revision as of 17:08, 15 December 2020 by Frank@tygron.nl (talk | contribs)
This testcase demonstrates a situation where a well is pumping up ground water. A characteristic ground water level curve will form over time. File:Drainage freatic benchmark.png
Stationary lowering of the ground water table in a closed water transmissive layer can be described by the following formula [1] ϕ(r)ϕ0=Q02πkDln(rR)
phi(0): stable water level at the considered stable water table edge
phi(r): water level between the considered stable water table edge and the well
phi(rw): water level in the well
kD: transmissivity of the aquifer in m² / day
r: distance to the well
R: distance of the considered stable water table edge to the well
Q0: amount of water pumped out in m³ / day
  1. Cite error: Invalid <ref> tag; no text was provided for refs named verruijt70
