Radial well aquifer benchmark (Water Module)
Revision as of 15:55, 16 December 2020 by Frank@tygron.nl (talk | contribs) (Setup)
This testcase demonstrates a situation where a well is pumping up ground water. A characteristic ground water level curve will form over time.
Stationary lowering of the ground water table in a closed water transmissive layer can be described by the following formula [1]
ϕ(r)ϕ0=Q02πkDln(rR)
phi(0): stable water level at the considered stable water table edge
phi(r): water level between the considered stable water table edge and the well
phi(rw): water level in the well
kD: transmissivity of the aquifer in m² / day
r: distance to the well
R: distance of the considered stable water table edge to the well
Q0: amount of water pumped out in m³ / day
Setup
We use the following setup in our tests. The grid size used is 51 by 51, with a configurable cell size of dx in meters. There is one underground outlet, which pumps water away continuously with a default amount per second.
The outlet is placed on the cells x = 25 and y = 25 as an inlet with a negative inlet.
INLET Q is set to Q03600*24
UNDERGROUND is set to true (1.0) to place the outlet below the surface.
The simulation is run for 64 days with 0 rainfall, which is configured in the weather's rain attribute as: [64243600,0]
  1. Verruijt, A. (1970). Theory of Groundwater Flow. Macmillan, London.
