Radial well freatic benchmark (Water Module)
Revision as of 16:38, 17 December 2020 by Frank@tygron.nl (talk | contribs) (Created page with "This testcase demonstrates a situation where a well is extracting ground water in a confined freatic layer. There is no aquifer present. A characteristic ground water level cu...")
This testcase demonstrates a situation where a well is extracting ground water in a confined freatic layer. There is no aquifer present. A characteristic ground water level curve will form over time.
Stationary lowering of the ground water table in a closed water transmissive layer can be described by the following formula [1]
h(r)2=h02+Q0πkln(rR)
phi(0): stable water level at the considered stable water table edge
phi(r): water level between the considered stable water table edge and the well
phi(rw): water level in the well
k: hydraulic conductivity of the freatic layer in m / day
r: distance to the well
R: distance of the considered stable water table edge to the well
Q0: amount of water pumped out in m³ / day
Setup
We use the following setup in our tests. The grid size used is 51 by 51, with a configurable cell size of dx in meters. There is one underground outlet, which pumps water away continuously with a default amount per second.
The terrain height is set to 0 meters (datum).
The outlet is placed on the cells x = 25 and y = 25 as an inlet with a negative inlet.
INLET Q is set to Q03600*24
UNDERGROUND is set to true (1.0) to place the outlet below the surface.
To stabilized the water levels on the edges of the test case , an additional underground inlet is used. It is located on all cells equal to or further away than the chosen R. This inlet is configured as followed:
Inlet Q set to 0, such that is unlimited.
UPPER_THRESHOLD set to -2 m.
LOWER_THRESHOLD set to -2 m.
The ground bottom distance is configured as 10 meters, which places the bottom at -10 meters (datum).
The water storage fraction is set to 0.25. The Terrain infiltration md (Water Overlay) infiltration m / day is set to k. The [[Ground vertical to horizontal factor (Water Overlay)|vertical to horizontal factor] is set to 1.0, which results in the same conductivity vertically as horizontally.
The simulation is run for 64 days with 0 rainfall, which is configured in the weather's rain attribute as: [64243600,0]
Test results
Important in all these tests in the chosen R, which is the distance to the well that is considered a stable water level. Additionally, the measurements are done relative to the impenetrable soil, which is situated 10 meters below the surface.
Test case 1
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 50;
Simulation days n: 64 days;
File:5m 50m3 k.png
Test case 2
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 50;
File:5m 50m3 k.png
Test case 3
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 50;
File:5m 50m3 k.png
Test case 4
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 50;
File:5m 50m3 k.png
Test case 5
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 25;
File:5m 25m3 k.png
Test case 6
cell size: 5 m;
kD: m/day;
R: 110;
Q0: 100;
File:5m 100m3 k.png
Test case 7
cell size: 2 m;
kD: m/day;
R: 110;
Q0: 1;
File:2m 1m3 k.png
Test case 8
cell size: 2 m;
k: m/day;
R: 110;
Q0: 16;
File:2m 16m3 k.png
Test case 9
cell size: 2 m;
kD: m/day;
R: 110;
Q0: 4;
File:2m 4m3 k.png
Test case 10
cell size: 2 m;
k: m/day;
R: 110;
Q0: 4;
File:2m 4m3 k.png
Test case 11
cell size: 2 m;
k: m/day;
R: 110;
Q0: 4;
File:2m 4m3 k.png
  1. Verruijt, A. (1970). Theory of Groundwater Flow. Macmillan, London.
