Align elevation (Function Value)
Revision as of 10:30, 13 January 2021 by Godelief@tygron.com (talk | contribs) (Godelief@tygron.com moved page Align evaluation (Function Value) to Align elevation (Function Value))
Function value | Attribute | Unit | Per category | Range | Description |
Align Evaluation | ALIGN_EVALUATION | Boolean | Construction | Attribute that determines whether a construction is aligned relative to the height map (in case of an uneven surface), flat on the ground, or floating. |
