Align elevation (Function Value)
| Function value | Attribute | Unit | Per category | Range | Description |
| Align Elevation | ALIGN_ELEVATION | Integer | No | 0 to 2 | Attribute that determines whether a Building is aligned relative to the elevation model (in case of an uneven surface), flat on the ground, or floating. |
The possible values for the attribute are:
0 = flat on the ground
1 = floating
2 = aligned to the elevation model.
- How to add Functions for editing
- How to change Function Values for a Function
- How to add an Attribute to a Function
- How to change Attributes for a Function
- Solar panels attribute for adding solar panels to Buildings.
Example of alignment to uneven surface with solar panels Tygron Platform (Dutch only)
