Ground transpiration formula (Water Overlay)
Revision as of 12:49, 25 February 2021 by Frank@tygron.nl (talk | contribs)
For all underground evaporation calculation, the ground water depth at time t is used. dgw,t=bswg,t
Feddes oxygen stress factor: Failed to parse (unknown function "\begin{cases}"): {\displaystyle f_o = \begin{cases} 1.0 & \text{if } d_{gw,t} \text{ is } >= d_{r,3}} \\ \frac{d_{gw,t} - d_{r,4}}{d_{r,3} - d_{r,4}} & \text{if } d_{gw,t} \text{ is } >= d_{r,4}} \\ 0.0 & \text{otherwise} \\ \end{cases} }
Feddes saturated zone root update factor: Failed to parse (unknown function "\begin{cases}"): {\displaystyle f_s = \begin{cases} 0.0 & \text{if } d_{gw,t} \text{ is } >= d_{r,1}} \\ 1.0 - \frac{d_{gw,t} - d_{r,2}}{d_{r,1} - d_{r,2}} & \text{if } d_{gw,t} \text{ is } >= d_{r,2}} \\ 1.0 & \text{otherwise} \\ \end{cases} }
Max potential evaporation: Emax=ftEwfo
Evaporation unsaturated: Failed to parse (unknown function "\begin{cases}"): {\displaystyle E_{u} = \begin{cases} 0.0 & \text{if } d_{us} \text{ is } <= 0.0} \\ min(E_{max}, h_u \cdot \frac{d_{r,1}}{d_{gw,t}})& \text{otherwise} \\ \end{cases} }
Evaporation saturated: hs=wg,t(bsdgb) hr=max(0.0,wg,t(bsdr,1)) Esp=(EmaxEu)fs Es=max(0.0,min(Esp,hsfgw,hrfgw
Evaporation total is the sum of evaporation in the saturated and unsaturated zone: E=Eu+Es
where
bs is the datum height of the surface.
wg is the underground water level.
d is the column height of the unsaturated zone.
ft is the transpiration factor of the buildings (plants) on the surface, or the surface terrain's
[Terrain_water_evaporation_factor_(Water_Overlay)|transpiration factor]] if none present.
Ew,t is the evaporation rate of the weather at time t
f0 is the feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
Related
Groundwater level formula
Models
Underground model
Evaporation model
