Ground evaporation formula (Water Overlay)
Revision as of 14:04, 25 February 2021 by Frank@tygron.nl (talk | contribs)
For all underground evaporation calculation, the ground water depth at time t is used.
dgw,t=bswg,t
Feddes oxygen stress factor:
fo={1.0if dgw,t is dr,3dgw,tdr,4dr,3dr,4if dgw,t is dr,40.0otherwise
Feddes saturated zone root update factor:
fs={0.0if dgw,t is dr,11.0dgw,tdr,2dr,1dr,2if dgw,t is dr,21.0otherwise
Max potential evaporation:
Emax=ftEw,tfo
Evaporation unsaturated:
Eu={0.0if dgw,t is 0.0min(Emax,hudr,1dgw,t)otherwise
Potential evaporation saturated:
ds=wg,t(bsdgb)
dr=max(0.0,wg,t(bsdr,1))
Ep,s=(EmaxEu)fs
Evaporation saturated zone:
Es=max(0.0,min(Ep,s,dsfgw,drfgw))
Evaporation total is the sum of evaporation in the saturated and unsaturated zone:
Eg=Eu+Es
where
bs is the datum height of the surface.
wg,t is the ground water level (datum height) at time t.
dgw,t is the depth of the ground water level, which is equal to the column height of the unsaturated zone at time t.
ft is the transpiration factor of the buildings (plants) on the surface, or the surface terrain's transpiration factor if none present.
Ew,t is the evaporation rate of the weather at time t
fo is the calculated feddes oxygen stress factor, calculated using the 3rd and 4th root depths and the feddes trapezium interpolation model and the ground water depth.
fs is the calculated feddes saturated zone root update factor, calculated using the 1st and 2nd root depths and the feddes trapezium interpolation model and the ground water depth.
dr,n is the nth root depth value.
Emax is the potential max evaporation
Eu is the evaporation in the unsaturated zone
Ep,s is the potential evaporation in the saturated zone
Es is the evaporation in the saturated zone
Eg is the total evaporation from the underground.
dgb is the ground bottom distance
ds is the column height of the saturated zone covered by the roots
Related
Groundwater level formula
Models
Underground model
Evaporation model
