Align elevation (Function Value)
Revision as of 14:22, 4 March 2021 by Rudolf@tygron.nl (talk | contribs)
Function value | Attribute | Unit | Per category | Range | Description |
Align Elevation | ALIGN_ELEVATION | Boolean | Attribute that determines whether a construction is aligned relative to the elevation model (in case of an uneven surface), flat on the ground, or floating. |
The possible values for the attribute are:
0 = flat on the ground
1 = floating
2 = aligned to the elevation model.
- How to add Functions for editing
- How to change Function Values for a Function
- How to add an Attribute to a Function
- How to change Attributes for a Function
- Solar panels attribute for adding solar panels to Constructions.
