How to manually configure a Water Overlay
Introduction to Manual configuration
When first added to the project, each variant of the water overlay will be created with a default configuration which will allow for an initial calculation to take place and results to display. For most use-cases, it is desirable to add additional data and tweak the settings and parameters of the overlay. This will improve the accuracy and relevancy of the overlay. It is possible to configure the parameters manually, or by using the configuration wizard. A few settings can only be changed manually. Besides the data of geographical features, which have their own means of loading in depending on their type, all manual configuration options are listed here.
Grid cell size configuration
Main article: Grid overlay
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The/any Grid Overlay (Left panel) → Change grid (Right panel)
Like all grid overlays, the water overlays have a number of configuration options related to their general method of calculation. Most notably, it is possible to configure the cell size on which the calculations occur.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → General tab (Right panel) → Calculation preference
The calculation preference indicates the level of accuracy the calculations should be performed with. Depending on the configuration timesteps will be calculated more conservatively. This affects the time it takes to perform the full calculation, and the exact quantities of water moving between cells.
Main section: Weather
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → Keys tab (Right panel) → "Edit", next to weather
The weather configuration, which dictates the duration of the simulation, the amount of rain and the evaporation rate, is modeled as a separate weather object which is connected to the water overlay. The weather object can be replaced with another, changing the main simulation and weather properties. The weather itself can be changed as well.
By selecting the weather object and then switching to the "Simulation" tab, it's possible to change the settings of the weather either for a simple linear setup or with a more complex sequence of values for the duration of the simulation. The complex setup can be created by loading in a CSV (comma separated values) file. By switching to the attributes tab of the weather object, the same properties can be adjusted by directly modifying the attributes.
Ground water configuration
Main section: Ground water
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Include ground water tiff (Left panel) → Keys tab (Right panel)
A ground water GeoTiff can be loaded in to prepopulate the underground with water in the form of a saturated zone. This is only a relevant configuration when the underground model is active. A ground water GeoTiff is optional. If no ground water tiff is selected, the assumed ground water level is equal to the WATER_LEVEL of the water area.
The presence of a ground water GeoTiff can be toggled by checking or unchecking the "Include ground water tiff" checkbox. When checked, a number of GeoTiffs are available for ground water levels by default. Other GeoTiffs for groundwater levels can also be loaded in by clicking on "Select GeoTiff".
Subsidence configuration
Main section: Subsidence
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Include subsidence (Left panel) → Keys tab (Right panel)
It's possible to connect the water overlay to a subsidence overlay, if one exists in the project. The result of the subsidence calculation, specifically the amount the terrain has lowered, are applied to the terrain height at the start of the water model's simulation. A connection to a subsidence overlay is optional. If no subsidence overlay is connected, the terrain height is not adjusted in this fashion.
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Show system visualization (Left panel) → General tab (Right panel)
The water overlay performs a simulation in which much detailed flow takes place, but in which a number of features perform special functions related to water flow. These features include the sewers and the hydrological constructions. The flow of these sections of the hydrological model can be visualized as an explicit graph overlayed on the overlay.
Active in simulation setting
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Active in simulation (Left panel) → General tab (Right panel)
Like all grid overlays, the water overlays can be configured to either an active or inactive state. This is especially useful when the results of a calculation should be available for insight without the computational overhead of always recalculating the overlay when changes in the project take place.
Result type configuration
Main section: Result type
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → Result type (Left panel) → General tab (Right panel)
The water model performs a complete simulation in which water flows through the project area. For many use-cases only a specific type of output resulting from the simulation is relevant. The result type of the water overlay indicates exactly what kind of data is recorded and outputted.
Note that via the configuration wizard multiple result types can be added in parallel in the form of result child overlays.
Legend configuration
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → Legend tab (Right panel)
Depending on the selected result type, the output created by the water overlay can or should be interpreted in different ways. The raw data calculated is assigned colors based on the configured legend. Each result type has an assigned default legend which helps with interpreting the output. The default legends will often be sufficient, but can be modified to fit specific meanings or result ranges.
Keys configuration
Main section: Keys
The water model's calculations rely on a number of areas and constructions for their input data. Hydrological features and hydrological constructions have special meanings in terms of policy or scenario. To allow for both compatibility with external data as well as parallel calculations for different scenario's, it is possible to (re)define the exact attributes the overlay uses for those inputs. This would allow two instances of a water overlay to work with the same dataset but with different configurations for hydrological features or constructions.
Keys
The water model makes use of data present in geographical features in the 3D world. This data is used as input for the various calculations which together model the water flow. The water model recognizes what attributes of geographical features form the parameters required for the calculation through key definitions. Each key is the name of an attribute which the water model should use to determine a specific parameter.
Keys are set to default attribute names, which apply to hydrological features, hydrological constructions, and hydrological properties of terrain. Keys can be changed so that imported data can be interpreted without renaming attributes, or to allow different configurations to come forth from the same dataset.
Attributes configuration
Main section: Attributes
Editor → Current Situation (Ribbon tab) → Overlays (Ribbon bar) → The Overlay to edit (Left panel) → Attributes tab (Right panel)
The water model's calculations make use of a number of centralized parameters, which are configured as attributes of the overlay. Depending on the exact variants of the water overlay, some of the parameters will have different defaults to better suit the exact type of calculation. The parameters can be tweaked further to better fit specific use-cases, but in general the defaults are appropriate for most calculations.
More Information
