Surface infiltration formula (Water Overlay)
First, the infiltration capacities are calculated:
Failed to parse (syntax error): {\displaystyle I_{surface} = min(\bar{I_{ground}}, \bar{I_{top}}}) Then the actual infiltration: <math>\Delta w = min( h, \Delta t \cdot I_{surface})}
Where:
- = The average infiltration speed based on constructions on top of the surface, based on GROUND_INFILTRATION_MD.
- = The average infiltration speed based on the surface terrain, defined by GROUND_INFILTRATION_MD. This value should be interpreted as the vertical conductivity (Kv) of the sub-soil.
- = The average infiltration speed on top of the surface.
- = The average infiltration speed below the surface.
- = The (limited) infiltration speed from surface to the unsaturated zone.
- = The amount of water on the surface. Also known as the water column.
- = The surface infiltration which takes place.
- = Computational timestep.
Related
- Formulas
- Surface water level formula
- Groundwater level formula
- Underground infiltration formula
- Models
- Surface model
- Underground model
- Infiltration model
- Tracer flow model
