Version 2022.0.1
Revision as of 09:38, 30 July 2021 by Maxim@tygron.com (talk | contribs)
Version 2022.0.1 is a Preview update released on preview.tygron.com on July 30th 2021.
Water
  • Added advanced option (LOWEST) to lower the DEM below bridges, improves flow.
  • Bugfix for multiple rain areas with dynamic rain/time.
  • Flow in object (e.g. culverts) is now visualized in tool in M3/sec instead of M3/timeframe.
  • New attribute to set water level relative to surface (instead of datum height) in Water Areas.
Ground Water
  • Added max infiltration amount when using "infiltration only".
  • Added attribute to set default groundwater depth when no TIFF or water area is provided.
  • Added attribute to set the initial saturation level of the unsaturated zone.
  • New result Overlay that shows the storage in the unsaturated zone only.
  • New result Overlay that shows the saturation level (%) of the unsaturated zone.
Geo
  • Improved OpenStreetMaps "Ditch & Stream" detection for waterways outside the Netherlands.
Other
  • Several smaller bug fixes.
